Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 04-09-2008, 09:08 AM
stirling is on a distinguished road
running steppers slowly
I have an application where I don't need fine resolution. Having done my sums it appears I'm going to be running my (200steps/rev) motors in the range 0 to 2 revs/sec so 0-400 fsps.
I understand how torque is inversly proportional to speed, but looking at the torque curves I notice that they only start at around 500 fsps - is there anything "funny" I should be aware of going on at the front of the curve i.e. when running motors slowly?
If it makes any odds I'll be using microstepping drivers.
Ian
Old 04-09-2008, 10:04 AM
Gold Member
Mariss Freimanis is on a distinguished road
Yes, there is something "funny" going on. The speed-torque curve shows from 500 full-steps and higher because there are severe resonance notches (down to zero torque) in the curve from 0 RPM to 500 RPM. Otherwise torque is constant from 0 RPM up to several hundred RPM past which it drops inversely with speed. Low speeds require microstepping to get resonance-free operation and full low-speed torque.
Mariss
Old 04-09-2008, 11:05 AM
Thanks Mariss - So not a problem if I use quality microstepping drives? - got any recommendations?
Whilst you're around... Could I ask you to take a look at my last post in " I thought I knew - now I'm not so sure..." please - it's about a paragraph in the stepper guide on the gecko site.
Ian
Old 04-09-2008, 01:00 PM
Gold Member
Please send a link to it.
Mariss
Old 04-09-2008, 01:37 PM
http://www.cnczone.com/forums/showth...632#post436632
Post #11
Ian
Old 04-16-2008, 04:40 AM
So... The torque curves for my motor show torque starting at 500fsps to be around the 2.5Nm (354 in oz) mark. Given I'll be using a quality microstepping driver can I assume the following?
There is absolutely no point in doing "the norm" of using a Voltage several times the rated voltage. Because I'm never going to get to the speed where torque drops inversly with current.
i.e. I should use the rated voltage of my motor.
This sounds too easy (for once)
Comments appreciated.
Ian
EDIT: Ah but of course at least one quality driver says the Voltage must be at least 4 times the rated Voltage - Other comments still appreciated though. Thanks.
Old 04-16-2008, 10:26 AM
ger21's Avatar
I believe that if you try to run the motor at it's rated voltage, the torque will drop off immediately as soon as it starts to turn.
Old 04-17-2008, 01:30 AM
Zappautomation is on a distinguished road
Also the driver will have a minimum voltage that will be at lest twice the rated voltage of the motor.
Below this voltage and the driver will not start.
Ian
Zapp Automation Ltd
www.slidesandballscrews.com
[IMG] code is Off
2.3v 3A/Phase steppers running at 35v, what amperage? guru_florida Stepper Motors and Drives 6 03-05-2008 10:27 AM
Getting my V2XT started (very slowly) LandCruiserLuke Bridgeport and Hardinge Mills 1 01-11-2008 03:38 PM
Coolant leaking slowly on back of VF3 Rocko1 Haas Mills 3 12-06-2007 05:38 PM
running high Amp steppers question. Semisentient Xylotex 1 04-21-2006 05:59 PM
Steppers running Hot? drakesis Stepper Motors and Drives 9 07-05-2005 09:25 PM
