Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 08-13-2004, 07:21 PM
cbcnc is on a distinguished road
Help Me Figure the Specs of My Motor.
I have a stepper motor that seems to have promise as a good motor but, I know very few of the specs.
Can you guys help me?
Here is what I know and how I know it:
Nema 23, 8 wire motor - visual
2.4 ohms/coil - I measured it
4.3 volts - Label
1.8 amps/phase - Label
120 oz/in unipolar - I measured it,
- Piker controller @24 V w/10 ohm resistor - each phase.
I would like to know how much holding torque it has in a bipolar series and parrallel. I don't have a bipolar board and so I wanted to power it up direct to measure the holding torque. How big should my current limiting resistors be for both series and parrallel?
Thanks for your comments.
Chris
Old 08-13-2004, 09:19 PM
ger21's Avatar
120 * 1.4= 168 oz-in bipolar.
Bipolar series should be about 1.25a, 6V. Bipolar parallel about 2.5a, 3V
Old 08-13-2004, 10:40 PM
Gerry,
How did you figure the 1.25a, 6v in series and 2.5a, 3v in parallel? Is there a formula?
Chris
Old 08-14-2004, 11:21 AM
ger21's Avatar
Bipolar series amps is unipolar amps x 0.7, volts is unipolar volts x 1.4
Bipolar parallel amps is bipolar series x 2, OR unipolar amps x 1.4, volts is bipolar series volts /2, OR unipolar volts x 0.7
Bipolar series ohms is unipolar x 2, parallel is unipolar/2, series is 4 x parallel.
This may only apply to 8 wire motors, not sure.
[IMG] code is Off
Vexta Stepper Motor Specs met4life Stepper Motors and Drives 9 03-05-2011 02:19 AM
servo motor specs and help cowanrg Servo Motors and Drives 3 06-11-2005 07:11 PM
motor specs? miljnor General Electronics Discussion 0 02-28-2005 10:49 PM
Understanding (European) motor specs - help WoodSnarfer Servo Motors and Drives 3 01-16-2005 05:13 PM
Looking for some motor specs Snipes44 General Electronics Discussion 10 10-30-2003 10:14 AM
