Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 04-05-2008, 01:22 PM
machining fool is on a distinguished road
Angry Stepper motor to simple power feed?
I have an old Bandit control on a Bridgeport, and I am tired of buying cards that blow up at 400.oo a shot, so I want to convert these steppers X and Y, to simple variable speed feed. Has anyone done it? If so, I would appreciate some help, Bob.
Old 04-12-2008, 09:53 AM
johnmac's Avatar
johnmac is on a distinguished road
Bob, I'm not a machinist, but I will give you some problems I think I see.
If you use gearmotors, you may not be able to hand feed while the motor is coupled. If you have a hand wheel at the motor, it may take a lot of cranking due to the gear reduction. If the gearmotors don't have brakes, you may have trouble not overshooting the stop point.
Sounds like you need stepper drivers with a built in controller that lets you run the motors without external control. Then you could have push button switches for direction control.
I used to service machines that worked this way. It had slow and fast buttons and rocker direction switches.
Just my thoughts.
John
Old 04-12-2008, 10:08 PM
Just my thoughts.
John
Hi, this is Machining Fool. Thanks for your reply. I am using this machine as a manual machine with little cranking force. One of the members sent a schematic of a circuit to convert, but I am having a little trouble understanding the circuit, but I think I will try to make it. Thanks.
[IMG] code is Off
Suitable circuit for using stepper as power feed staffordshirech General Electronics Discussion 24 07-13-2009 09:38 AM
Stepper Motor Power kylecroft Stepper Motors and Drives 4 05-02-2007 11:24 PM
Stepper Motor Power Requirements GAWnCA Mechanical Calculations/Engineering Design 0 04-07-2007 01:44 PM
Stepper Power Feed Mr.Chips WoodWorking 0 11-03-2005 12:01 AM
How to find out how much power (oz/in) do I need for stepper motor? max7687 Stepper Motors and Drives 8 09-18-2005 03:57 PM
