Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 04-04-2008, 10:57 AM
haroldj is on a distinguished road
5-phase driver ups503-1
I just got 2 ups503-1 controllers from ebay but got no documentation with them. Can anyone tell me how to wire these to accept step/dir signals from the parallel port? These are made by Mycom, but thier site says they are discontinued. I did find somewhere that said they could be used with step/dir signals, but not how to hook them up. Any help appreciated.
Old 04-18-2008, 09:02 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
The ups 503-1 controller has been superseded by the IMS500 series 5 Phase
Half/Full Step Driver.
Go here
http://www.mycom.com.sg/products.asp?opt=2
and click on the PDF link under the controller details.
It has a switch on the controller to change from 2 pulse to 1 pulse which you will need for the step/direction signals (you will need 1 pulse for your computer setup).
This should get you out of (or into) trouble.
Rich.
I am not completely useless.......I can always serve as a BAD example.
Old 04-20-2008, 12:40 PM
Thanks Rich
I assume that I could hook up from the step/dir control right from the parallel port and just wire in the 5 volts as in the diagram and make sure the switch is in the 1 position. Any idea which is step and which is direction on the card hookup?
Harry
Old 04-21-2008, 06:31 AM
MonoNeuron's Avatar
Yes. But a breakout board is much better because it is so much easier to wire everything up. Get the C10 from CNC4PC for $25. It's cheap and does a great job and has isolated inputs.
In part 8 section 4 (Signal In/Out connector) near the bottom of the page you can see the "CW and (Pulse) "
and underneath it "CCW and (CW, CCW) "
These would be the Pulse or Step
and the Direction is CW, CCW
Old 04-26-2008, 12:05 AM
Stepper Monkey is on a distinguished road
Instructions with mine say to move switch four from the "B" position to the "G" position. All of mine are marked "1P" and "2P" though. Set it to "1P" if yours looks that way. Your +CCW now becomes "direction", and your +CW becomes "step". -CCW and -CW become unused.
Confusing as hell I know, Mycom could have documented it better.
[IMG] code is Off
has anyone the specs for a 5-phase-stepper driver? Arquibaldo Stepper Motors and Drives 12 12-19-2009 01:06 PM
5-phase stepper driver? skandragon Stepper Motors and Drives 5 04-03-2008 09:15 PM
4 phase driver help required cmeikle Stepper Motors and Drives 0 10-01-2007 04:19 AM
3-phase stepper driver inquiry extrapilot Stepper Motors and Drives 4 07-26-2007 03:16 PM
5-phase driver UDX5128NA George Onsen Stepper Motors and Drives 0 02-18-2006 12:09 PM
