Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-16-2008, 07:55 AM
markraws is on a distinguished road
Question please help before i loose my mind :(
hello all
as you can tell im new to the cnc world,i have purchased this board...http://www.easy-cnc.com/web/download...l3and4Axis.pdf
and these motors...http://www.motioncontrolproducts.com.../fl60sth86.pdf
i am total lost...and scared
please any help form you guys will be more than welcome,theres gota be some one out there
Old 03-16-2008, 08:16 PM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
If you head on over to www.geckodrive.com Mariss has some very useful tutorials on steppers which are fairly generic and is very good reading if you are new to the scene. People can tell you what wire to put where but it is no use if you don't understand WHY.
If you still can't work out the configuration then come back here and post again. I'm not being nasty, I'm just trying to get you up to speed without rehashing what has already been covered a thousand times here and it will make you feel a lot more comfortable with what you are doing.
I go back there from time to time to relearn a few things and it is a great resource that is readily available.
Here is the link.
http://geckodrive.com/photos/Step_motor_basics.pdf
Or just go to www.geckodrive.com and click on support and follow the links to a wealth of information. Mariss is probably the foremost guru on these things here in this forum and is also probably one of the most helpful. Not an easy combination when running a business like his.
Rich.
I am not completely useless.......I can always serve as a BAD example.
Old 03-16-2008, 09:42 PM
hybidder is on a distinguished road
Mono makes some great suggestions.
I'll also recomend getting a breakout board, it will streamline (somewhat anyway) your connections and if you get one that's opto-isolated will also help protect your pc. There are several "start to finish" threads here you might look up a few of those as well.
What are you planning to build?
Old 03-23-2008, 04:24 AM
you guys are the best,i plan on building a small router for now,i have a homemade cnc 10x5 footprint,but its not the best.I am also working on a new router(10x5) and i will start a build log
im preety much new to the forum and i need to know if i can cut steel sheet 5,6mm with a router
thanks guys and i will stay in touch
Old 03-30-2008, 07:44 AM
MonoNeuron's Avatar
Hi again markraws
To cut steel you would need a router that is very stable and heavy..i.e a lot of mass. You need this to absorb the vibrations from cutting. A wood router really isn't up to the challenge of steel cutting and only the very best ones advertise themselves as being able to cut Aluminium. If you need to cut steel then try your hand at CNC'ing a cheap vertical milling machine. Don't get the round column ones as the Z axis alignment will be too hard to keep and you would have to modify it way too much. Try for a dovetail vertical slide. There are some cheap secondhand ones around.
Keep reading and throwing around questions and it will all come to you oneday. It's a fairly steep learning curve but this forum really helps to iron out a lot of questions from everyone. No one is versed in all things CNC but a few are well equipped to guide you on the right path to where you will get most of the info you need.
Also try the Yahoo forums for the CADCAMEDMDRO forum where a lot of the people here are also active.
I wish you well in your adventures. (and hope it doesn't cost too much :-) )
Rich.
Old 03-30-2008, 11:22 AM
Thank you so much guys your a great help,i think a trip to the steel cutting shop is in hand
waiting on parts and will start the log soon.cya
[IMG] code is Off
loose column on h-400 TACKER Mazak, Mitsubishi, Mazatrol 1 01-11-2007 07:04 AM
I'm gonna loose it!! k-linkz Stepper Motors and Drives 3 12-27-2006 06:15 PM
I got a screw loose Karl_T Servo Motors and Drives 0 12-01-2006 05:55 PM
Loose Spindle nut highhat Benchtop Machines 2 09-01-2006 03:18 PM
