Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-13-2008, 08:30 AM
weeli is on a distinguished road
retired toolmaker/cnc programmer
hi, this is my 1st post. looking for info on ASTROSYN steppers TYPE 23KM-K036-P5V. NO T3819-01. Would also like sugestions on diy drivers. I built a small desktop mill and is in the process of fitting these steppers and planning on using Mach 3 for hobby cncing. Any help and sugestions wil be apreciated. I am a electronics moron so keep it in mind please.
Old 03-13-2008, 02:37 PM
pminmo's Avatar
pminmo is on a distinguished road
How many wires are the motors? Any other info on the nameplate?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 03-14-2008, 02:08 AM
hi Phil. Thanx for reply. Stepper has six wires dual 8mm shafts and is made by MINEBEA
Old 03-14-2008, 09:58 AM
pminmo's Avatar
They can be run either unipolar or bipolar, so it would depend on the current rating of the motors. You might see if any of this info helps make an educated guess at the coil currents: http://www.eminebea.com/content/html...pdf/23km_k.pdf
Old 03-14-2008, 02:20 PM
Thanx, it looks like 3amp 100oz motors, might be a litle on the small side. Dont have a choice ,redundant motor supply in South Africa is scares.which diy driver do you sugest.As i mentioned on another thread i am thinking of running 2 of these per axis.
Old 10-25-2009, 12:07 AM
Abner is on a distinguished road
Hi, have you found more information about this model? I have a couple of these step motor. I would like to know the motor current and what voltage I should use to drive these motors.
Hope you can help me.
Old 11-17-2009, 11:47 PM
doraimontv is on a distinguished road
Hello.
I am another owner of two engines alike.
Do you know the features?
A greeting from Spain.
Old 11-22-2009, 03:10 PM
I couldn't find information for this particular stepper motor but I found some general information related to the 23km-k motors (hybrid motor).
doraimontv contact me if you are interested, I'm from Perú.
Old 11-22-2009, 03:50 PM
Yo le mande un email al fabricante y me contesto que el motor esta fabricado para una marca y no pueden dar información sobre el.
Old 11-25-2009, 10:12 PM
Lo he usado a 5 voltios y pasa 1amp por fase, lo probé a 12 voltios y la corriente ya pasa los 2 amp. Creo lo recomendable sería darle unos 8 voltios, me falta probar esto. A 5 voltios el driver (L298) calienta bastante hay que tratar de enfriarlo.
Saludos
[IMG] code is Off
Art Fenerty has retired (Mach 3 Artsoft) ynneb Mach Software (ArtSoft software) 28 02-04-2008 09:56 AM
Wanted: retired machinist… produce aluminum parts... Ontario Canada ngr1 Employment Opportunity 2 04-27-2006 09:02 PM
Looking for side/retired machinist for small project marklongmont Employment Opportunity 1 02-24-2005 09:07 PM
