Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-09-2008, 10:36 AM
mulligan is on a distinguished road
Buying Drivers and power supply AGAIN!
Starting from scratch again... I purchased the K179 drivers and power supply a year ago and recently found that they have proven to be quite in adequate for my Oxy/fuel/plasma table. My budget for the table is about nil right now so the best bang for the buck parts is needed.
I have two Keling 289oz and one 425oz. At the current time I will only be running two axis.
Which of these will be my best bet and why:
1. http://www.hobbycnc.com/products/hob...er-board-kits/ - 95.60 incl shipping + power supply
2. http://www.xylotex.com/3AxWPS.htm - 205.00 + shipping
3. http://cpwojcik.home.att.net/QSDriver/Page_1x.html - 210.00 + shipping + power supply OR 2 drivers + quickstep software + Pulse Spacer incl shipping - 250.00 + power supply
Also is there a 'universal' power supply I can buy that I can use for any of these?
What about this one?
http://www.xylotex.com/24VDC_4-5A-PowerSupply.htm - 50.00 + shipping
Or
http://www.staples.ca/ENG/Catalog/ca...affixedcode=WW 50.00 + tax
Old 03-09-2008, 10:41 AM
I've been suffering from information overload for the last couple of weeks and need someone in the now to advise me.
Old 03-09-2008, 11:01 AM
plexer is on a distinguished road
Would one like this:
http://cgi.ebay.co.uk/350W-24V-14-5A...QQcmdZViewItem
Be any good?
Ben
Old 03-09-2008, 02:01 PM
pminmo's Avatar
pminmo is on a distinguished road
How big is your table, and what is your method to convert rotary movement to linear movement, screw, rack......? You might want to look at this: http://pminmo.com/PMinMOwiki/index.p...chanical_Power
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 03-09-2008, 09:04 PM
y table is 5'x9' with a useable space of slightly more then 4'x8'.
I have a timing belt setup now. Not sure how well it works yet due to issues with my power supply.
I have 10t on my motor to a 30t which is on a shaft with a 20t that moved the axis... I'm not sure if I am geared low enough.
I lucked out with an old Compaq Desktop Pro I had with a 200w power supply. After reading info on these pages (http://www.wikihow.com/Convert-a-Com...b-Power-Supply and http://www.directron.com/2powersupplies.html) I was able to set it up to run my current K179 drivers.
I will still need to order some higher quality drivers to optimize my setup... but I have no idea the pros and cons of each.
A year ago when I order my current hardware, I thought I was set...
Old 03-10-2008, 08:05 AM
pminmo's Avatar
Can't say that I understand the relation ship of the three (10t, 30t, 20t) ? Is one of them a rack?
Getting the mechanicals right first will help you in the end, otherwise you will be spend more money on power supply and drivers.
[IMG] code is Off
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Keling motors, drivers and power supply connections Nitroghost Automation Technology Products 14 03-13-2008 11:18 AM
Buying torroid power supply? alexccmeister Stepper Motors and Drives 3 04-09-2007 08:08 PM
Steppers, Drivers and Power supply robertg991 Stepper Motors and Drives 21 05-21-2006 09:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
