Results 1 to 4 of 4
Thread: Stepper motor and rotary table
    Apr 2007
    Denmark
    Red face Stepper motor and rotary table
    I just got control of my step motor from on old HP matrix printer with a small C# program of my own.
    I'm not impressed of the "power" of the motor. I want to use it for turning my rotary table to make the table a simple dividing head.
    To be sure the stepper has turned the table the degrees I want it to I see too solutions:
    1) use some kind of feed back to my program to insure that in fact the table has turned the degrees the stepper was told to turn the table by the program
    OR
    2) use a stepper so strong I sure it can turn the table - even with some resistance - no feed back is needed because the stepper is so "strong" I can be sure it has turned the table
    What is the "all round best" solution ?
    Best regards
    KSor, Denmark
    Registered vger's Avatar
    Jan 2006
    Closed loop is generally best (feed back to the controller) but it requires additional hardware (encoder) and software to read the feedback. I don't know what rotary table you have, but you could use reduction drive from the stepper you have to gain the torque needed. Small timing belt/pullys setup might work for you.
    Steve
    Feb 2007
    cheapest way would be to use a larger stepper
    steppers have the most torgue at low rpm,and a rotary runs fairly slow anyway,so pulley
    reduction on a small stepper wont always give better results,i prefer a larger stepper with direct drive,if you use a small stepper with endcoer (closed loop)you will know its moving correctly but,your motor still wont have the power to cut much
    Apr 2007
    Denmark
    Thanks for the "feedback" SORCHEROR and vger !
    Best regards
    KSor, Denmark
  1. How do you use a rotary table?
    By ranchak in forum General Metal Working Machines
    Last Post: 01-30-2008, 11:30 PM
  2. Haas stepper rotary table question...
    By cabledude in forum Stepper Motors and Drives
    Last Post: 12-11-2007, 05:29 PM
  3. Converting a Haas stepper rotary table?
    By cabledude in forum Haas Mills
    Last Post: 11-24-2007, 04:30 PM
  4. Helical Coupler for Stepper -> Rotary Table
    By patmul in forum General Metal Working Machines
    Last Post: 11-22-2006, 01:32 PM
  5. Rotary Table Servo Motor
    By bigbigJimbo in forum Servo Motors and Drives
    Last Post: 09-25-2005, 02:09 AM
