No you can't calculate the output from the resistance. The output is determined by the ratio of secondary to primary turns, but the primary of a step down transformer will use much thinner wire so the ratio of resistances will be much higher than the turns ratio.
Assuming they are step down transformers then the highest resistance will be the primary.
You can wire the secondaries in series to add the voltages if you get the polarity right.
LinkBack URL
About LinkBacks
