Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-04-2008, 02:42 PM
Aaronem is on a distinguished road
Steper and driver choice
Hi All
I have almost competed the frame, gantry and linear bearings of a 1.5m x 1.5m woodwork router, and need to acquire stepper motors and drivers system. The gantry wieghs about 79 kg, and lead screws are 16mm dia with 4mm pitch. I am in the UK and need to find a cheap solution. What spec will I need for motors, or what speed will the tool have to move.
These are on ebay....The holding torque is 14kg.cm. They are 3 amp, 2.55 volts with 1.8 degree stepping angle. The dimensions are 78mm x 56 mm x 56 mm. Hope this helps.
No other info available yet, will they do?
Any help would be really appreciated
TIA
Aaron
Old 03-05-2008, 07:01 AM
vger's Avatar
vger is on a distinguished road
Aaron,
Those motors are rather small (NEMA 23's most likely) for trying to move that heavy a gantry. You might get away with it doing a high gearing (belting) ratio but it'll take lots of steps to move very far and your speed will suffer greatly. Look for some much larger motors.
Steve
Old 03-05-2008, 10:33 AM
pminmo's Avatar
pminmo is on a distinguished road
While the following is in inch units, the technicals on driving lead screws and transfer of mechanical power via a stepper might be usefull reading for you: http://pminmo.com/PMinMOwiki/index.p...chanical_Power
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 03-05-2008, 12:55 PM
Zappautomation is on a distinguished road
The motors are too small, unless you are happy with a very slow speed.
Originally Posted by Aaronem View Post
Hi All
TIA
Aaron
Zapp Automation Ltd
www.slidesandballscrews.com
Old 03-06-2008, 06:24 AM
Oldmanandhistoy is on a distinguished road
Take a look at http://www.motioncontrolproducts.co.uk/ for motors and drives. I use there MSD*** drivers and find they have been very reliable and fairly priced.
John
Old 03-06-2008, 05:53 PM
Kipper's Avatar
Kipper is on a distinguished road
I bought these some time ago and @79KG your gantry seems "large" enough to need some grunt! 12nm motors are awesome (imo) I have no reservations with these drivers/motors I just turn it on and away it goes... ebay MCP Not sure I need all that grunt on all axes though...But it can't hurt lol
Keith
[IMG] code is Off
Steper motor driver board needed maydayy CNCzone Club House 3 12-22-2007 07:21 AM
choice of diy servo driver package GMS Open Source Controller Boards 2 10-03-2007 09:27 PM
steper+gecko201+2" /turn b/s driver ... help ammar Linear and Rotary Motion 2 11-05-2006 01:44 PM
Steper Motor & Driver Problem -Please Help Chivo Gecko Drives 5 08-29-2005 06:10 PM
Steper Motor & Driver Seting--- Please Help Chivo Stepper Motors and Drives 4 08-24-2005 07:15 PM
