| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I know someone will spot what I am missing. I am building a high percision router completed to the electronic stage. The table is 2' x 2' , will post step by step pics after I have it all done. I am having a problem with getting the motors to move. I am running mach 3 to a bobcnc break out board which controls 4 gecko 203v motor drives. the steppers are kelinger 495 oz and the power supply is 24 volt to start with. I will upgrade power for smoother operation after I have it working. It seems that everything checks out like the limit switches on the diagnostics page, I can jog the DRO but I can't get any response from the motors. I have have played with the pin setup in Mach 3 with all different configurations with no change. Does anyone see anything that I could be missing? |
| Do you have +5V to the common on the drives from the breakout board? You may have the common set to ground on the breakout board.
| What model Breakout board do you have? The G203v needs controller ground to the common terminal. If your BOB has a jumper to control whether the common on the board is +5v or ground. Set the jumper to ground. ***************** From the G203v manual: The COMMON return for the signals is controller ground referenced instead of +5VDC. This greatly eases the drive to controller interface. (TERM. 10) COMMON Connect this terminal to the controller ground output. Verify COMMON goes to your controller GND *************** cheers, Jack
__________________ Walking is highly over-rated |
Oops, had that backwards. Way too tired today. Thanks for the correction.
| NO movement, Any suggestions for my gecko 201 and Mach3 setup? | journeyonline | Machines running Mach Software | 1 | 11-15-2007 03:45 PM |
| help plaese no stepper movement | timmyb199 | Mach Software (ArtSoft software) | 5 | 10-27-2007 08:13 PM |
| No idea how to setup the stepper motor | Syphonics | Stepper Motors and Drives | 12 | 03-06-2007 08:43 AM |
| stepper movement | jaypal | TurboCNC | 1 | 01-08-2007 04:18 PM |
| Dual stepper motor setup | Goose80 | Stepper Motors and Drives | 7 | 12-19-2006 11:46 PM |
