Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-28-2008, 05:08 PM
Motorcoach1's Avatar
Motorcoach1 is on a distinguished road
Pittman motors /Calcom
Have 2 24volt 19-1 ratio pittman motors salvaged fro a Calcom drawing master. does any one have a driver board that will run these. I'm only working with X and Y axes. The tolerance that will be cuting is 1/6 in 1/4 inch glass. All so If any one has salvaged parts from one of these I need them , it will save me in haveing to make them, I'd be happy to pay you for these parts . bearing mounts/ bearings, need 4 off main roller. Cog timeing pullys also. Have steppers with 40-1 gear that will work also. The reason i'm useing these is the work is wet all the time and need to put boots on the motors. I cut square and rectangle holes in glass and building a portable system. I designed a circut that will work with switches and 2 relays. I wanted to put a little automation with the machine to be replacatable and have the holes in a file i can call up. Have a Disc insturments Optocal encoder If any one is interested I'm not sure how these work seeing, I'm new to CNC set ups . but I'm haveing fun learning. One more question - in the take up spooler there is a small board , is this a driver boaed? or just a power F/R electronic switch. thanks Mike
[IMG] code is Off
425 oz in motors a bit hot oddatwl Xylotex 5 07-26-2008 10:12 PM
DC motors as servo motors Doug Schwochert Servo Motors and Drives 5 12-26-2007 12:03 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
Elcom Pittman Brushless DC Motors Prboz Servo Motors and Drives 6 03-28-2006 03:41 AM
33 Oz/in Motors Are They Enough chadwiggan Machine Problems, Solutions , Wireless DNC, serial port 4 01-10-2004 05:09 PM
