Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-22-2004, 04:41 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Nema 23 Or 34?
Ive Been Scanning Through Price Lists And Was Wondering Why I Would Pay More For A Nema 34 Motor Instead Of Just Buying A Nema 23 Motor With The Same Torque At Around 30.00 Dollars Cheaper Per Motor. Is It Because Of The Larger Diameter Shaft On The 34?
Someone Please Clarify. Thanks
Old 07-22-2004, 05:07 PM
Chagrin is on a distinguished road
Although the max torque might be equivalent, the torque curves for the two motors probably keeps the 34 ahead (steppers lose torque as they increase rpm, y'know). The 34 is probably overall sturdier as well.
Old 07-22-2004, 05:09 PM
sendkeys is on a distinguished road
only reason i can think of if you wanted more metal to work with . and the 34 should help a little with heat. be little stronger.
But no real reason. other then "supply and demand"
*edit*
Chagrin is right you should check both motors torque curves amps volts ect
Old 07-23-2004, 02:36 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Is the nema 34 a stepper or a servo, we'll need to move this thread either to the servo or stepper motor forum.
I'll do it as soon as you guys let me know which one....
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 07-23-2004, 10:31 AM
FLUTE HEAD's Avatar
Gold Member
Reply To Moderator
Stepper Not Servo, Sorry
Old 07-23-2004, 10:34 AM
FLUTE HEAD's Avatar
Gold Member
Thanks Everyone, I Didn't Think About The Torque Curve.
Old 07-23-2004, 11:22 AM
ger21's Avatar
Yeah, from the charts I've seen, typically 34's have flatter curves than 23's
Old 09-01-2004, 02:31 PM
andyew's Avatar
andyew is on a distinguished road
But from Dan's sale on Nema 34's, they seem to have cheaper price for torque/dollar compared to his other Nema 23's. Let say 220oz.in Nema23 is the same as 300oz.in Nema34 (around 80 bucks each). Correct me if wrong......
I think Nema34 is disadvantageous in terms of the torque/weight (of the body) compared to its cousin 23. While 23 with 220oz.in torque is more "efficient" than 220oz.in Nema 34...... What do ya think??
Andy
[IMG] code is Off
RFQ Nema 34 to Nema23 Mounts redbaron Employment Opportunity 4 04-29-2005 03:59 PM
Souce for NEMA 42 stepper motor? Mueller Stepper Motors and Drives 2 03-06-2005 08:59 PM
What does NEMA mean ? ynneb FAQ of CNC Machine building 0 08-17-2004 09:24 AM
NEMA standards ynneb General Electronics Discussion 3 08-17-2004 08:32 AM
Nema 23 Mounting Bracket Dimensions Sanghera Stepper Motors and Drives 3 07-28-2004 06:41 PM
