I would encourage anyone that has a question on the boards posted on my website to post their questions there in the bulletin board. http://pminmo.com/phpBB2/
I review it multiple times a day. Here I'm lucky to catch such a posting because of the volume of posts on a subjects.
As to your specific problem, it's likely a pcb problem (open or short) associated with the following:
IC1 pin 1 or 2
IC3 pin 1, 3, 4 , 6, 11 or 13
IC8 pin 5 or 9.
You can use the onboard logic probe to see if those pins change state when you change direction.
The above aslo assumes you have the software setup correctly.
LinkBack URL
About LinkBacks
. FYI, I just found the forum you mentioned but can't complete activation till this evening (can't log into yahoo at work).
