Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-18-2008, 11:15 PM
woodlice is on a distinguished road
different size motors
Can you use different size motors on a cnc router or will this cause problems like needing 2 power supples for the different volt amp ratings say nema 34 600 oz/in and nema 24 200oz/in?
Old 02-19-2008, 07:09 AM
cueshark is on a distinguished road
you did not say if they are servos or steppers. if they are servos they need to be real close in volts. if they are steppers then you would need a power supply that would be between 10 & 20 times the volts on the different motors. so you could be 10 x the volts on 1 motor & if the other motor specd half the volts as the first motor it could be 20x & you would be ok with the right ps. hope this helps more info on the motors would help.
greg
Old 02-19-2008, 12:49 PM
I was thinking of using 2 x nema 34 KL34H280-45-8A 640 oz/in 6.3A 2.3v 8 wires for x,y and 2 x nema 24 KL23H2100-30-4B 495 oz/in 3A 3.6v 4wires on the MDF CNC Router im building. It has grown from 600x600 to1mx1m. I'm really warried about using to small a motor but do you think this is over kill? would I have to have 2 power supplies or 2 driver boards or should I just go with 4 of the same motor? The motors are from Keling Technology, Inc. www.kelinginc.net
Old 02-19-2008, 04:02 PM
bobchiloquin is on a distinguished road
cueshark,
I'm a little confused. You talk about running steppers at 10-20 times the rated voltage. Does this mean I could run a 24v, .3A, 6 wire stepper at 240v to 480v without fear of it burning up?
Bob Hayes
Old 02-19-2008, 04:35 PM
ger21's Avatar
Originally Posted by bobchiloquin View Post
cueshark,
Bob Hayes
Possibly, if you could find a drive that would handle that kind of voltage. Most steppers used in CNC applications are in the 1.5V-5V range. And most users use power supplies in the 36V-72V range. Gecko drives are limited to 80V, and cheaper drives are usually less.
Old 02-19-2008, 05:04 PM
Gerry,
So my 24v steppers(Eastern Air Devices, p/n LA23ACK-3) probably aren't strong enough for my modified Joe's Hybrid router. There's no indication of torque on the nameplate. Y axis slides are modified, ball bearing, undermount drawer slides, mounted on 80/20 2x4 extrusions.
Bob Hayes
Old 02-20-2008, 12:04 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
Bob,
When running a higher voltage than the motor rating, you do need some way to limit the current. Most modern drives have some way to set the current. However, there are still a few drives being sold with no current setting, and if you get one, you will need external current limiting resistors in order to run higher voltages(current limiting resistor generate a lot of heat).
The reason for higher voltage(ie 10-20x the rated voltage) is maintain good torque at higher speeds. Higher voltage will make little if any difference in low speed torque. The torque from a stepper drops off as speed increases. Using higher supply voltages lessens the drop in torque. The reason you want motors rated 5 volts or less is that most drives have a voltage limit of 30-50 volts and even the better drives rarely handle more than 80 volts.
Jeff
[IMG] code is Off
New Machine Build- What size Stepper Motors? Oldboy Benchtop Machines 3 01-26-2008 12:14 PM
200oz motors vs. Table size? CoffeeRich Hobbycnc (Products) 9 01-15-2006 03:57 PM
Stepper Motors size? mtsrose DIY-CNC Router Table Machines 7 12-14-2004 10:21 AM
What size motors? I'm confused again :) Darren_T DIY-CNC Router Table Machines 15 08-31-2004 02:26 PM
how do i determine what size stepper motors to use? capitalv General Electronics Discussion 3 01-20-2004 02:22 PM
