| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello everyone, I am trying to connect stepper motor to the driver. For some reason instead of turning it makes noise. When I increase voltage the noise becomes louder but motor still doesn't move. I am wondering what could be wrong. |
| What kind of driver? What kind of motor? What is the power supply voltage?
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| I'm having the same problem. using EMC2, 24v supply, which is the rating for the steppers, and is within spec for the driver board (12v-36v). the noise coming out of it is just like the noise it would make if it were running, and holding it, it feels and sounds like it's trying to move, but the shaft doesn't actually move. stepper is not seized. brand new, and can turn with hand. when powering up the computer, the steppers all "hold" well, then release when the boot up is finished. Not sure if it makes any sense, but it almost seems to me like the steppers are trying to move, but are being held or something. The frequency of the noise is coordinated to what it's being told to do, with accelleration, microstepping etc. it all sounds like it's running, but the shaft won't spin. tried multiple (identical) steppers, all teh same, and on all 3 axis I'm using. triple checked wiring, and I think i have the pin layouts correct. i did notice my driver pin laoyouts have seperate pins for XYZ permission and XYZ Pulse, and the Permission ones make it actually do somthing, while the pulse pins dont' seem to. i know i probably don't have enough information, but this is a start in case anybody happens to fix "Finder"s problem, the solution will probably fix mine too. |
| Turn down your velocity and acceleration to very low values and atart there. Make sure you have the correct number of steps per unit configured. i.e. TPI - step size. For example a single start 10tpi at half step would be 4000 steps per inch.
| ESTOP!!! mine works now. the X "permission" is really an estop out. I'm relatively new to cnc, so i didn't put two and two together... at least not in the right order. so i just kept trying different pin definitions until it finally worked. if at first you don't succeed... part of my problem was my ignorance, and part was due to my pin descriptions being translated by someone from chinese that isn't familiar with the concepts of cnc, just a literal language translation. anyhow, this was my first post and i intend to get more involved in the future. Thanks again!!! |
| Estop won't keep the motors locked........
#11
| You got it working that is what is important. Doubt there is two wrongs as Estop doesn't work like that.
| Sanyo P5 1kw brushless motor spin video | KTP | Servo Motors and Drives | 24 | 02-07-2009 09:34 PM |
| Stepper motor noise | dmparrott | General Electronics Discussion | 5 | 10-03-2007 10:35 AM |
| MACH3 and noise from stepper motor | timeout555 | Mach Software (ArtSoft software) | 3 | 02-28-2007 09:39 PM |
| Can bad forward/reverse toggle cause motor not to spin? | ZipSnipe | General Electronics Discussion | 16 | 06-03-2006 08:45 AM |
| TAIG "head" makes alot of noise | Smertrios | Taig Mills & Lathes | 17 | 02-25-2006 04:25 PM |
