Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-16-2008, 09:25 PM
Mongkol is on a distinguished road
Smile How to calculate angular velocity from hybrid stepping motor?
Dear All,
I am building plasma table by using hybrid stepping motor. I am little puzzled on calculation. Who know the formula to find angular velocity of hybrid stepping motor? I want to take it to find the force(kgs) which is possible of motor to drag load.
Here's my spec. of hybrid stepping motor.
1) 1.8 degree per step.
2) Rate current at 2.7 Amps.
3) Phase resistor at 2.9 Ohm.
4) Phase inductor at 17.5 mH.
5) Holding torque at 850 N.cm min.( about 1200 oz.in)
6) Detent torque at 24.5 N.cm max.
7) Rotor inertia at 2500 g.cm2
8) Lead wire at 8 wires.
Hope your help
Mongkol
Old 02-16-2008, 09:34 PM
Smile How to calculate force (kgs) to drag load of hybrid stepping motor?
Dear All,
I add some details. It can work at 80 -160 VDC.
Mongkol
Old 02-17-2008, 07:51 AM
ger21's Avatar
Force (ounces) = ((2 x pi x torque)/ lead) x screw efficiency.
You'll need a torque chart for you motor to find it's torque at any given rpm.
Old 02-17-2008, 06:48 PM
Smile How to calculate for timing belt system.
Hello Gerry,
Thanks for your help. My system is T5 timing belt,not ball screw.Do you have other formula?
Mongkol
[IMG] code is Off
Drive for 3-phase hybrid stepper motor Newbie2CNC General Electronics Discussion 9 08-13-2009 06:20 AM
Stepping Motor Sanyo-Syn 103-820-2 chockstef Stepper Motors and Drives 5 06-10-2009 04:05 AM
help me in stepping motor ibrahem_mo Mechanical Calculations/Engineering Design 0 08-28-2007 04:22 PM
Where to buy stepping motor birdofcnc Stepper Motors and Drives 9 01-12-2006 05:21 PM
How do I calculate the strength of a motor? bb99 DIY-CNC Router Table Machines 7 12-04-2003 05:32 PM
