| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I am new to the CNC world and would like assistance. I am in the process of building my small cnc router for inlay work. I have an AlienCNC 3 axis driver board (sorry-should have done my research) with Keiling Technology 185 oz stepper motors. They are rated at 1.86 V @ 3.0 amps/phase for bipolar (parallel) and 2.19 V @ 1.5 amps in series mode. I understand this driver board likes 2.0 amps/phase to run correctly and maxes out at 2.5 amps/phase at 30Vdc. My question and I am open to all suggestion is: How should I wires the motors? I have attached the pdf specs from my motors. Thanks! |
| Hi, If your question is, how should I wire them parallel or series? Then I would say try them both ways in your circumstances. If your question is which wire to where, then take a look here for different wiring methods http://www.wimb.net/index.php?s=motion&page=52 John |
My questions was directed more towards the capabilities of the aliencnc driver board. Will it handle the motors wired in papallel mode? It seems that I remember this driver board not running correctly if it was the below the 2.0 amps/phase. Thanks for the link. Mike |
| I would presume you have on board adjustment for current. The motors will have no problem running just below 2.5Amps/phase and will in fact run cooler (better for the motor). The only down side to running lower than max current is it will reduce the amount of torque available from the motor. |
| I am surprised to hear there is no current adjustment but if you are sure. If it is the case then I would replace the board with another reputable board. I have no personal experience of these boards but have seen the bad reports. As I remember it’s down to not receiving the board in the first place. As for the quality or lack of I can’t say. If I were in your situation I would do a search and find out more. If the board is likely to fail quickly I would replace it immediately due to the damage that could happen to your machine during failure. If you are willing to risk it then you take your chances and hope it fails whist not cutting and is under your supervision so you can hit the E stop. good luck, John |
#11
| I think he forgot to post the link.
| When should I go from series to parallel? | Oldmanandhistoy | Stepper Motors and Drives | 20 | 03-14-2007 08:26 AM |
| parallel vs series | miro | Stepper Motors and Drives | 3 | 01-25-2007 10:52 AM |
| Series/Parallel Bipolar | chas | DIY-CNC Router Table Machines | 0 | 09-01-2004 01:38 AM |
| What is a series and parallel circuit? | ynneb | DIY-CNC Router Table Machines | 0 | 04-27-2004 09:58 PM |
| series or parallel | turmite | General Electronics Discussion | 5 | 12-28-2003 10:27 PM |
