Results 1 to 4 of 4
Thread: Stepper motor and driver for faceting machine
    Apr 2004
    Illinois
    I am designing a faceting machine that I would like to incorporate a digital index system for the angle and index setting. I have very limited electronic experience, (could not build my own board ) but have retrofitted two CNC mills. I am looking for advice/help on this project.
    The basic design of the machine control:
    Axis 1 : I will need a stepper motor to move a stop plate on a rotatory axis to a specified angle setting and hold. I would like to enter the angle in degrees from 0 (from horizontial) and the motor move the stop to that location. The head will then free pivot and touch this stop.
    Axis 2: Is a motion that involves index settings (positions) based on number of gear teeth of a given diameter,ie 32,48,64,80,96,120 . Here again I would like to enter the number value and the motor index to that angle based on a home "0" setting.
    I am experienced in CNC programming and 5 axis work so I know what a Gcode program would look like for the B& C axis if programmed. I don't want to have to program but it might be a possibility. I don't know if Mach 3 could be configurated so that I could use it for manual entry for each axis or if a stand alone display is what I would need.
    My dream system would be a laptop or a small touch screen like an Automation Direct plc interface that would operate each axis.
    Any help or direction would be greatly appreciated as I have just about got the mechanical part of the machine designed .
    Thanks in advance
    Jim Walthall
    Registered vger's Avatar
    Jan 2006
    Thoughts
    Most steppers do 1.8 degrees / step, or 200 steps / revolution. Microstepping drives can get you to 0.9 degrees (1/2 step), 0.45 degrees (1/4 step, and so on. If you want exact degrees (360 / rev) you may want to use reduction gearing/belt/worm to get you there. I might suggest worm gear drive for your application. Worm drive would just about preclude you from accidently bumping the stepper out of position.
    108:1 worm would give you one minute steps (60 / degree) in full step.
    Sounds like a great project. Diamonds ??
    Steve
    Apr 2004
    Illinois
    Steve,
    Thanks for the reply. Yes I was going to use a worm gear for the index.
    I was looking at a worm reduction of 36 to 1 because that gace me the size I needed and also it was divisional into the standard index gears that are used in facet designs. I will look into a 108 to 1 and see what I can find.
    Anyone out there have any imput on the front end of the control. Is Mach 3 what I want and just configure the screen . I would really like a pendent with jog buttons for each direction of rotation and a readout of what index setting I was at. I would also need a readout for the angle setting. Any person that can do this please contact me.
    Once again thanks for the reply.
    No not diamonds, colored gemstones
    Cheers,
    Jim W
    Jan 2006
    ratios, wheels, etc.
    Got my interest. Did a quick look at faceting machines and found the Ultratec site. They have index gears that have 32, 64, 72, 77, 80, 96, and 120 teeth.
    A quick calculation gives 221,760 as the least common multiple of those values. That comes out to 616 steps / degree.
    So if you can come up with a gear ratio that will rotate your dop 1 degree with 616 steps, you would be able to hit any angle that any of their gears will do (and a lot of points in between).
    Might take a double worm as in a speedometer, but could be done.
    Not sure as to which software might be best for this. Seems you might want the g-code to have several pauses in it and just index to the next successive pause.
    Are you looking to automate the post height as well ?
    Steve
  1. 1.7V 4.7A Stepper motor which driver
    By motorsports in forum Stepper Motors and Drives
    Last Post: 01-21-2008, 10:12 AM
  2. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors and Drives
    Last Post: 10-16-2007, 05:56 PM
  3. Stepper motor driver via PC
    By cibot in forum Stepper Motors and Drives
    Last Post: 01-13-2007, 06:43 AM
  4. CNC Faceting Machine
    By dsadams in forum Mechanical Calculations/Engineering Design
    Last Post: 02-06-2005, 11:55 AM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors and Drives
    Last Post: 01-03-2005, 06:05 PM
