Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-01-2008, 05:10 PM
aticio is on a distinguished road
Datasheet for Stepper Motor needed
Dear all!
I´m searching for a datasheet for a Stepper motor
I know only the things written on a label which is on the back of the motor:
127K43531
STP-58D3004
1.8°/Step 0,48 Ohm
2534OG
Does anyone know the Manufacturer of this motor an further know where to get a datasheet for it?
The most important thing I would like to know the "Holding Power" (I hope you know what i mean) an the current the motor consumes.
Any Help would be appreciated !
Thanks in advance!
Kind Regards
Aticio
Old 02-02-2008, 04:20 AM
art887 is on a distinguished road
Aticio,
I belive that is a Shinano Kenshi product code. You might want to try their website. I have some STP-58D4002-03 I bought for $8 at Allelectronics and I thnk they are about ~100 oz/in holding torque.
Hope this helps.
Art
Old 02-02-2008, 10:32 AM
Thanks a lot.
I tried it already on the Site of Shinano Kenshi but did not find anything which is fitting to this motor.
Also i tried to write a mail to Shinano Kenshi, but no answer at all.
How much is ~100 oz/in in European words?
Thanks again
Kind Regards
Aticio
Old 02-02-2008, 10:58 AM
The value from an Asian language datasheet was actually 9.1 Kg/cm (~126 oz/in).
cheers,
Art
Old 02-02-2008, 11:25 AM
Hi.
@art887: Thanks.
The actual SST58D3xxx Series from Shinano Kenshi has about 7,3kg/cm and
the SST58D4xxx Series has 9,2kg/cm.
So I think mine has about 7,3kg/cm.
Does anbody have another (better) info about my motor?
Thanks a lot!
Kind Regards
Aticio
Old 10-16-2008, 10:35 PM
cad01 is on a distinguished road
Aticio, or has anyone else found out the specs for this motor. I found these at my local surplus store. any info would be great.
brad
Old 10-17-2008, 03:12 AM
Hi.
No, sorry.
These motors are still laying around here.
I found nothing more about it.
I would be very pleased about more info also!
Kind Regards
Aticio
Old 11-03-2008, 08:31 AM
Oxyd is on a distinguished road
Hello everyone.
Recently i have ordered FL60STH86-3008BF stepper motors, but it seems that i received little different ones, because some dimensions are a bit different from FL60STH86-3008BF. On the motor label it says: "60HS88DE103D-01". I've tried looking on the net for any information, but couldn't find anything. Also i wrote an email to the seller, but still no answer, so i'm asking you for help. I need a datasheet for this motor, because i can't wire it correctly to MSD542 driver. It keeps buzzing and tries to turn to both sides at the same time, so it simply keeps twitching forward and backwards.
Old 11-04-2008, 12:21 PM
tobo123 is on a distinguished road
I ordered ht6088-3008bf and received 60hs88de103d-01.
Try here for description of model No. (http://www.3xmotion.com/english/defa...pper_Motor.asp)
also (http://www.motioncontrolproducts.co..../FL60STH86.pdf)
shows colour codes of cables. To get mine running in series I had to reverse the green winding to what it indicated on diagram. Now run sweet.
cheers
tony.
Old 11-15-2008, 10:10 PM
Oxyd
see wiring diag
hope this helps
tony
  #11   Ban this user!
Old 11-16-2008, 06:53 AM
Originally Posted by tobo123 View Post
Oxyd
see wiring diag
hope this helps
tony
Yes that was very helpful. Motor turned from first try perfectly and had torque. Thank you very much. Now all it's left to put them in their place, finish mounting for spindle, wire everything up and i'm ready to go for a test run.
  #12   Ban this user!
Old 11-26-2008, 08:30 AM
hi oxyd,
here is parallel config you req. for 60hs88de130d stepper motor (msd542 driver)
A+ red/white and blue
A- red and blue/white
B+ black and green/white
B- black/white and green
i'll be changing mine to this, higher top end.
regards tony
[IMG] code is Off
Stepper Motor Power Needed? ballchain Stepper Motors and Drives 3 10-15-2007 10:17 PM
Datasheet for STP-58D207-01 (Step motor) duykhoi02cdt Stepper Motors and Drives 0 04-02-2007 10:50 PM
Siemens Motor Datasheet Source? GrindEngineer Servo Motors and Drives 8 01-09-2007 07:46 AM
Help Needed! Stepper motor acting up... nuplowboy Stepper Motors and Drives 1 10-02-2005 01:03 PM
help with stepper motor datasheet/specifications zoltan Stepper Motors and Drives 5 08-11-2005 03:12 AM
