Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-29-2008, 11:20 PM
dlbrt is on a distinguished road
IMS IM1007-NR Stepper-motor Driver
I need an IMS IM1007-NR stepper-motor driver for one of my laser engraver/cutters.
Can anyone help me?
Thanks,
Don
Old 02-01-2008, 05:15 PM
Zappautomation is on a distinguished road
This was made obsolete over a year ago.
I would contact the IMS distributors and see if any have it in stock, but i suspect that you will not have any luck because this is not a standard IM1007.
Originally Posted by dlbrt View Post
Can anyone help me?
Thanks,
Don
Zapp Automation Ltd
www.slidesandballscrews.com
Old 02-01-2008, 05:21 PM
Thanks Zapp,
Do you know the difference between the IM1007, 1007ie and 1007nr?
Don
Old 02-01-2008, 05:54 PM
Yes, the IM1007 is a drive only (Clock and direction)
IM1007I has an indexor built in, the IE also has encoder feedback.
THe NR has a noise reduction filter.
It is likely that the manufacture of the machine would have tried the standard IM1007, and needed to use the NR due to noise.
This is a 10A driver so you are going to need to check you motor, to see if you can get away with a smaller driver.
The next one down is the IM805, this is a 7A driver, and is comparable to the Gecko drive, but i know of a few OEM customers who tried to save some money and use the Gecko instead of the IM805, and quickly changed back.
Saying that the IM805 is about $400.
I think it is very unlikely that you will get the IM1007 driver anywhare, let alone the NR version.
I would save time and look for an alternative.
Zapp Automation Ltd
Old 03-19-2008, 05:35 PM
designer is on a distinguished road
IM1007
If you still need 1 I may be able to help
Old 03-19-2008, 05:55 PM
Trevor,
Is it the IMS IM1007-NR?
Old 03-19-2008, 05:59 PM
i will check
brb
Old 03-19-2008, 06:02 PM
there is 2 x im1007 and 2 x im1007-NR - HP1
Old 03-19-2008, 06:09 PM
yes IM1007-NR the is a white rectangle after the nuber with HP1 not sure what the HP1 is for the termination is the same as the IN1007.
Old 03-19-2008, 07:01 PM
the white rectangle is a sticker with hp1 written on it.
  #11   Ban this user!
Old 04-16-2008, 06:39 PM
triplett969 is on a distinguished road
dlbrt,
If you are still looking for a IM1007-NR I have one. It is used. Came from a piece of research equipment at the local university. Contact me and we can work out a deal (triplett969@gmail.com)
  #12   Ban this user!
Old 04-16-2008, 07:26 PM
Hi triplett,
How much do you want for it?
dlbrt
[IMG] code is Off
1.7V 4.7A Stepper motor which driver motorsports Stepper Motors and Drives 3 01-21-2008 10:12 AM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 05:56 PM
IMS IM1007 and ElectroCraft E643 Servo brush-motor per_jonsson Mechanical Calculations/Engineering Design 0 05-10-2007 09:24 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 06:05 PM
stepper motor driver snoman70 General Electronics Discussion 0 12-16-2004 08:41 PM
