Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-29-2008, 03:04 PM
jseiler is on a distinguished road
can you drive a stepper with 2 drives
I am curious if one can drive an 8 wire stepper with 2 drive channels be using each driver in half coil on the same motor? I envision connecting 1 drive to the a and b phases and another slaved driver to the c and d phases for double the current drive.
Old 01-29-2008, 03:11 PM
neilw20's Avatar
neilw20 is on a distinguished road
Exclamation Don't think so.
Good way to demonstrate locked rotors.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 01-30-2008, 06:51 AM
Why not?
Old 01-30-2008, 01:09 PM
keebler303 is on a distinguished road
I think it might be possible. Neil is referring to the possibility that the two drives are not in sync with one another, if they are not, they will be fighting each other and you will have a "locked rotor". If you were to lose a step or turn the machine off and back on, you might get the drives in different states, you would then have to send a step pulse to one drive and not the other until they were in sync.
Possible, probably.
Worthwhile, questionable.
If you have the parts, try it out. You will either find it doesn't work, it fries your drives, or it works great and you can tell everyone how to do it.
Good luck
Matt
Old 02-01-2008, 06:15 PM
cnclathew is on a distinguished road
cnc lathe
Hi guy, I have a cnc wood lathe project, and right know I have done all the mecanic stuff, I just need to buy the stepers motors and the drivers, but my main conser is the maybe I dont buy the correct step motor. I need some help, Im building something like this
As you can see the y axi have a saw as a cutter, so I have to put an electic motor on y axis, I guess the motor weight is around 25 lbs, so I need to now how many torque do I need for bout axis ( x, y)
Please advise I will apreciate
[IMG] code is Off
old stepper drives aegfurn Stepper Motors and Drives 3 12-21-2006 01:16 PM
BP BTC 2 stepper drives? DennisCNC Bridgeport and Hardinge Mills 2 09-11-2006 11:46 PM
Low Cost Stepper Drives drk Stepper Motors and Drives 0 08-01-2005 08:48 AM
IMS stepper drives icecube Stepper Motors and Drives 3 03-14-2005 09:19 PM
Phytron ZSO stepper drives Vikketsi Stepper Motors and Drives 2 02-09-2005 12:21 PM
