Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-28-2008, 03:55 PM
rkremser is on a distinguished road
is 175 extra oz worth $10 per stepper
Looking at buying some steppers, (first run at electronics). For $30 extra there is the option of upgrading the steppers to 305 oz from around 150oz. Good deal, not a good deal, is it worth it. Let me know opinions. Looking forward to responses. Thanks
Old 01-28-2008, 04:15 PM
FPV_GTp is on a distinguished road
hi
Try http://www.kelinginc.net/
cheers
Old 01-28-2008, 05:06 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
As far as I am concerned, the more power, the better. Without a doubt. If your machine is the size of a postage stamp, it might be overkill but if it's a reasonable size, you will likely be very happy with more powerful motors. Iit's likley you will find the limitations of any motor you put on, so when you find the limits of the 305s, you will likely be glad you didn't choose the 150s.
This is all speculation, of course.
That's my story.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 01-28-2008, 05:23 PM
ger21's Avatar
I'm with Scott. Spend the $30. Although letting us know what you'll be doing with them may give you a better answer.
pminmo's Avatar
pminmo is on a distinguished road
Motor size is dependent on machine type, size, rotary to linear conversion method. There are downsides to larger motors, they have more mass and have larger rotor inertias which typically translates in to slower accelerations and deceleration rates. Bottom line, it's all a system. Machines, motor, drives, screws, power supply all contribute to performance.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
[IMG] code is Off
Little extra help for tailstock bdyenter Daewoo/Doosan 0 10-17-2007 11:24 PM
G203 with the extra money? bryanrabb Gecko Drives 6 09-23-2007 04:17 PM
Just need Extra Income SPYLAGZ Employment Opportunity 0 08-09-2007 03:44 AM
Extra capacity cdlenterprises Employment Opportunity 1 02-26-2007 02:58 PM
Need help extra lines in dxf carlnpa Mach Software (ArtSoft software) 3 03-19-2005 04:48 PM
