| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Need some information on this driver. Have emailed General Controls but have not received a reply back from them. Anybody got a manual for this drive? Model: 29A55-A 3amps input: 28vac/42vdc Thanks U-all ![]() Greg |
| Hey Greg, Here's a link to an Ebay auction for a Dragon Driver. there's a link to the manual somewhere on that page. Dragon Driver |
| All you need to add is a transformer and a stepper. They can be used stand alone as a indexer or wire to a computer. Here is a copy of the pdf/ manual |
All you need to set them up is in the manual I posted. They only run from AC, they have a built in bridge rectifier to make DC. |
| My Breakout provides the following: 1. Enable 2. Direction 3. Step 4.. Common But the Dragon Driver has the following: 1. Step out 2. Step in 3. +5v out 4. Half/Full step select 5. CW/CCW Select 6. Enable 7. Ground 8. Fast osc 9. Slow osc 10.Ground Now of course I can understand the ground and enable probably wire up to common and enable on the breakout board. but I have no idea how I should wire the Direction and Step. Any help would be appreciated. BTW, I've read the PDF provided, and its still not clear to me. |
The enable from the BOB goes to the enable on the driver. The common on the BOB goes to the ground pin 7 on the driver. The step on the BOB goes to the step in on the driver. The direction on the BOB goes to the CW/CCW select on the driver. If you want full steps you connect half/full to ground, for half steps leave unconnected. Step out on driver is left unconnected. Fast osc and slow osc are left unconnected. |
#10
| Thanks Packrat. I messed around with it yesterday, and had come to pretty much the same conclusion. Good to have some confirmation on the connections. Will be taking my LNC2 box home from work today to test it all out. |
#11
| PACK DRIVER Model D2590 | lee2007 | Stepper Motors and Drives | 5 | 02-26-2009 12:57 AM |
| cb model pro? any one try it? | grahamshere | General CAM Discussion | 0 | 12-22-2007 03:04 AM |
| single axis driver and a b.o.b.,or multi-axis driver board | .xXACEXx. | Stepper Motors and Drives | 3 | 07-03-2007 12:13 AM |
| Info on Toshiba RA Driver, Model RAD02-2009 | DennisCNC | Servo Motors and Drives | 0 | 09-02-2006 07:50 PM |
| STEPPER DRIVER FAQ {Stepper/driver amp per phase match. | huios | Stepper Motors and Drives | 0 | 08-27-2006 09:43 AM |
