Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-24-2008, 08:48 PM
peiboy is on a distinguished road
Red face Vexta 5-phase / 10 Wire Steppers
Hi
I just bought a few 5 phase steppers to compliment the 5 phase drivers I have. Both are vexta, by oriental motors.
My problem is that the drives I have are 5 wire (Blue,Red,Orange,Green,Black) and the motors are 10 wire (Yellow, Black, White, Orange, Green, violet, blue, grey, red)
I have identified the pairs, but now I don't know what order the pairs should be in, and what order to hook them up to my driver is. (I assume that I will be grounding one leg of each pair).
Can anyone help me identify the phase order of these motors?
The motors are PK564-AA, and my drives are RKD514L-A
Thanks for your help
PEIBOY
Old 01-25-2008, 12:34 AM
jalessi's Avatar
jalessi is on a distinguished road
A little help
Hey Cat hope this helps.
See attached pic.
Jeff Alessi
jalessi@aol.com
Old 01-25-2008, 12:40 AM
jalessi's Avatar
Five Wire Image
Wiring information you need is on the bottom of the page of the attached jpg.
Jeff Alessi
jalessi@aol.com
ID:	51627   Click image for larger version
Old 01-25-2008, 12:58 AM
jalessi's Avatar
More Help
P.S.
Send me your email address and I will send you a pdf with more info.
Jeff Alessi
jalessi@aol.com
Old 01-25-2008, 10:05 AM
Jeff
Thanks a bunch! After I posted that I went digging around the Vexta website and found some of that information. I am so glad you could confirm my new suspicion.
I wonder why vexta is so tight lipped about this stuff? It doesn't seem to promote them as a company that you would want to work with.
My email is below, thanks so much for your help
Jonathan
Jonathan.macwilliams@gmail.com
Old 01-18-2009, 10:55 PM
huongthanh is on a distinguished road
Jeff Alessi
jalessi@aol.com
Hi Jeff,
Did you tried to build a 5-phase stepper motor? Could you share some more information?
I have a 5phases stepper motor (5 wires) with spec. 2.8A/Phase; 2.42V/Phase and 0.72o/Step. It is pentagon connection. I tried to build a driver use 89S52 as logic microcontroller and MOSFET as 5 half H-bridge (pls refer the attachment file). As above mention spec. of the motor then it will be turn one revolution with 500 step pulses (full step). But, actually it turns three revolutions with 500 step pulses from my driver.
Step sequence as below:
Terminal 1 +++-----+++++-----++
Terminal 2 --+++++-----+++++---
Terminal 3 +-----+++++-----++++
Terminal 4 +++++-----+++++-----
Terminal 5 ----+++++-----+++++-
Where is mistaken? Thanks
Old 01-19-2009, 09:29 PM
[QUOTE=jalessi;399412]P.S.
Jeff Alessi
Hi Jeff,
Could you kindly send me too? I am building a 5 phase stepper driver, but it works not properly. Any information about that is very great.
My E-mail address: huongthanh040307@gmail.com
Old 08-18-2009, 02:17 PM
jalessi's Avatar
Post 5 Phase Vexta Documentation
See attached file.
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
[IMG] code is Off
Vexta 5-phase stepping motor landart Stepper Motors and Drives 2 01-29-2011 02:18 PM
VEXTA Stepper with 5 phase kraft123 Stepper Motors and Drives 0 07-30-2007 03:04 PM
Vexta 5 phase questions brokencase General Electronics Discussion 0 05-18-2007 08:54 PM
Vexta 5 phase drive George Onsen Stepper Motors and Drives 4 03-10-2006 06:05 PM
5 phase vexta stal Stepper Motors and Drives 2 10-15-2004 08:35 AM
