Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-23-2008, 10:33 AM
Witsenburg is on a distinguished road
Gearing the bipolar motors, less RPM = better?
on my first build, the machine had a speed of 4mm/motor revolution, and the gantry was really, really heavy. So at higher speeds, the x axis motor stalls. (Interchanging motors and drivers between x and y axis, the problem remains on the x axis only.) Now my next build will have a lot lighter (better design, better material) gantry to move. And I read somewhere that bipolar motors have 'the most torque at the lowest RPM'. If I use belt-drive (toothed belt) with a small wheel direct on the motor axle, I get about 75mm/motor revolution. Making machining at 1500mm/min go at only 20 rpm, instead of 375. Would that be too much of a good thing, or will the motors really perform better at such low RPM? Is there a way to know (without expensive measuring equipment) in which rpm range a motor is most competent?
First build
The motors are HY 200 3438.
Cheers,
Hugo
Old 01-23-2008, 04:01 PM
pminmo's Avatar
pminmo is on a distinguished road
Stepper motors have more power at lower rpm's, this charactestic is true for unipolar and bipolar. Here is a sample power curve on a Vexta motor: http://pminmo.com/PMinMOwiki/index.p...e:Pk266pwr.gif
Higher voltage as is illustrated on the curve extends the power band.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-23-2008, 05:04 PM
Aha, so I need to search for such a diagram. Let's google:
Found a PDF!
Now I'm not entirely sure which motor I have (0280 or 0430), but it is save to say performance would be best between 300 and 900 steps/sec, right? Since I only use 45V, let's make that 300 - 800 steps/sec. 180 steps/rev, so 100 - 266 rpm would be on the money. Hey, my 375 rpm (1125 steps/sec) would be outside the borders! I would almost think I understand it!
Let's say middle performance should be 1500mm/min, and should occour at 183 rpm. That's 8mm/rev. Great, there's my answer: double spindle speed relative to motor speed (I use 4mm/rev thread, as mentioned in the first post). At least, if this all makes sense. Does it?
Cheers,
Hugo
Old 01-23-2008, 05:12 PM
ger21's Avatar
Yes, I'd shoot for somewhere between 6mm and 15mm per revolution. The downside is that you'll have lower resolution.
Old 01-23-2008, 10:11 PM
pminmo's Avatar
I haven't published this link yet, as I'm not completely sure I've thought thru the mechanics correctly: http://pminmo.com/PMinMOwiki/index.p...chanical_Power
It's similar to what you are examining but rather than gearing it's comparing different pitch lead screws, their efficiency and the mechanical advantage. Then coupling those with the typical stepper power curve.
[IMG] code is Off
Connecting bipolar motors without knowing which wire is which? Witsenburg Stepper Motors and Drives 1 05-12-2007 11:29 AM
bipolar/unipolar motors studysession General CNC (Mill and Lathe) Control Software (NC) 2 02-17-2007 02:50 PM
Bipolar from unipolar motors MrWild Stepper Motors and Drives 5 05-13-2006 11:56 AM
testing bipolar stepper motors from ebay cowanrg Stepper Motors and Drives 5 07-14-2005 02:11 PM
Bipolar Parallel or Bipolar half winding? Oldmanandhistoy General Electronics Discussion 20 07-14-2005 09:56 AM
