Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-20-2008, 04:23 PM
motorsports is on a distinguished road
1.7V 4.7A Stepper motor which driver
I am building a Flying gantry CNC Router, with 2 motors and leadscrews for the Y-Axis. 27" X 36"
I just bought 4 Superior Slo-sync motors (used) and their rating is as follows:
1.7V
4.7A
150oz*in holding torque
My next step is to buy a controller for these motors, but it seems their isn't much out there for the higher current controllers. I will need at least 10A/channel because the Y-Axis drive will have two motors connected in Parrallel.
First question is do you know of a good board that will run these motors?
Second Question: What will I need for a power supply? (Volts, Amp requirements)
Third Question: Am I better off buying a good board, and then buying motors to suit it.
Old 01-21-2008, 04:22 AM
hanermo is on a distinguished road
driver for 150 oz in steppers
Em ...
not to be negative, but you need a single driver for each stepper.
So you need 2 drivers for the y, and the controller sw (like mach3) is told to drive them together i.e. slaved.
There have been many threads / comments;
You cannot make 1 driver drive 2 steppers well.
Old 01-21-2008, 07:27 AM
Ok hanermo, Thanks
I had read a thread where someone was told they could run the two motors in Parallel, but they would have to remember to double the current capacity for that drive.
I will go for a board with fourth axis capability then.
Old 01-21-2008, 10:12 AM
ger21's Avatar
Actually, a member here has designed a 5amp board that will actually "slave" the two motors in hardware. It's a 4 axis board, but two of the axis' can be driven from a single input.
Bipolar Microstep 48 volt 5Amp /phase, 4 axis board
As was mentioned, you don't want to run two motors from one drive. You could also use Gecko's to drive those.
However, 150oz is on the low side - you may want to go with something bigger.
For $335, you can get four 305oz motors and a 4 axis driver from HobbyCNC.
http://www.hobbycnc.com/hcncpropkg.php
It also includes everything you need for the power supply except a 24V transformer and a case to hold everything.
[IMG] code is Off
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 05:56 PM
Stepper Motor Driver droddis DIY-CNC Router Table Machines 5 07-30-2007 08:03 PM
Stepper motor driver via PC cibot Stepper Motors and Drives 4 01-13-2007 06:43 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 06:05 PM
stepper motor driver starCNC DIY-CNC Router Table Machines 5 04-01-2004 09:00 PM
