Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-20-2008, 01:32 PM
millman52's Avatar
millman52 is on a distinguished road
Specs for an unknown stepper
Is there a way to calculate V & A on a stepper motor of unknown origin?
If it works.....Don't fix it!
Old 01-20-2008, 02:23 PM
pminmo's Avatar
pminmo is on a distinguished road
Is there any information on the nameplate of the motor? Manufacturer, or anything? If not you can partially start with physical size, you can count the number of wires, you can measure coil resistance.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-20-2008, 02:41 PM
millman52's Avatar
They are square black cased NEMA 34 steppers, 4 wire, they read 1-1.1 resistance. There are no markings what so ever on the cases.
This reading was taken at the end of 25' of 16 ga fine stranded wire with soldered connections at the motor.
Old 01-21-2008, 10:48 AM
pminmo's Avatar
What is the depth of the stepper? Compare the size to the nema 34's here: http://www.kelinginc.net/SMotorstock.html
That will give you a starting point, beyond that it becomes trial and error to most people. Start with a lower safe current, monitor the motor temperature, and adjust the current upward.
[IMG] code is Off
stepper specs jarvis89 CNCzone Club House 1 03-07-2008 12:23 AM
xylotex 4 axis board and unknown stepper motors abigroot Xylotex 5 04-11-2007 02:47 AM
Using temperature to find opperating voltage of unknown stepper? Splint Stepper Motors and Drives 0 03-14-2007 07:07 AM
Newbie needs help on stepper specs !! mbp Stepper Motors and Drives 2 05-16-2006 09:03 AM
Stepper Specs (Was Servo Specs) plexer Stepper Motors and Drives 1 09-29-2005 10:28 AM
