| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Given these two motors, when wired bipolar parallel: http://www.kelinginc.net/KL23H286-20-08B.pdf 425 oz-in 2.8A 4.17V http://www.kelinginc.net/KL23H276-30-8B.pdf 282 oz-in 4.2A 1.9V Does that mean to get the rated torque out of the 282 motor, I would need a driver with a higher current rating than to get the rated torque out of the 425 motor? But to get higher rapids on the 425, I would need a driver with a greater voltage rating? I think the 282 motor is enough for my application, but I don't want to use it if it would require a bigger driver than the 425. |
| Yes, you're correct. Holding torque is proportional to current, so you'd need a 4.2amp drive to get full holding torque from the 282oz motor, but only 2.5amps for the 425. Supplying higher voltages keeps the torque from dropping off quickly at higher speeds.
| Has anybody tried/used two smaller steppers per axis? The thought being it could give more power at higher speed (minimizing the inductance compared to one larger rotor) but still provide similar low speed torque to that of a bigger motor. Just wondered if this is feasible. Pres |
| Small or large jobs wanted for 5 axis cnc (woodworking) | Shawnm | Employment Opportunity | 2 | 04-13-2011 03:38 PM |
| Stepper for large mill ??? | Guido72 | Stepper Motors and Drives | 0 | 01-13-2008 02:13 PM |
| 340 or 320 with large motor | johnd | Gecko Drives | 1 | 05-11-2005 04:07 PM |
| Using a large drive on small motor? | murphy625 | General Electronics Discussion | 0 | 03-11-2005 05:23 PM |
| How to Run a Large Stepper On A Small Board without frying | Sanghera | General Electronics Discussion | 8 | 04-27-2004 06:39 PM |
