Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-08-2008, 10:08 AM
kreutz is on a distinguished road
Kreutz-4B, 4 axes bipolar Micro-Stepper drive kit (48V/5A) Specs.
-Kreutz-4 Rev3.0N (K-4) is a Bipolar, Chopper current control, 4 axes set.
-K-4 accepts 4 or 8 wires motors (and 6 wires motors leaving one wire disconnected on each phase)
-48 Volt Maximum power supply voltage, 15 Volt minimum (Each power board automatically disables when the motor power supply voltage goes over or under the limits).
-5 amperes peak phase current per axis (2 Amps minimum). Individually adjustable by potentiometers and test points.
-The low voltage power supply (+12 Volt) is also monitored to be between 16 Volt and 8.5 volts, otherwise the boards get disabled.
-Idle current reduction (50%) after 1 second inactivity independently for each axis.
-Over current and over temperature protection.
-K-4 can be used on the following modes: Full Step, 1/2, 1/4, 1/8, 1/16, 1/10, 1/5.
-Automatic torque compensation.
-Reference waveform "morphing".
-Firmware Upgrade capability built in.
-External Output connector for interfacing the rest of the LPT port pins.
-Charge-Pump (watch dog) circuit disables the outputs if the 12 KHz signal is not received from the software, protecting against Software "freezes" and LPT cable disconnections.
-4.3 volt brownout protection by resetting the micro-controllers.
-Opto-isolated Inputs and Outputs (except External Output interface signals). RF isolated Step-direction signals up to 2500 volts
-Basic set includes 5 boards (PC interface board with B.O.B. functionality, and 4 power boards).
-3.3 volt or 5 volt PC interface (jumper selectable)
-"Torque Loss" LED, shows you when the motor current can not follow the reference, indicating Torque Loss at the corresponding speed or speed range.
-Firmware Ready LED (for each axis), Service/Adjustment blinking LED.
-Axis Disabled LED (for each axis)
-Current reduction LED (for each axis)
-PC power LED
-Charge Pump OK LED
-E-Stop LED
-Low Voltage Power LED (on every Power board)
-Maximum Step rate: 100 Khz
-Minimum Step and Direction pulse width = 2 uSec @ 100 Khz.
-Step and direction signals are Active "High"-
-Active average current compensation for variable PWM duty cycle.
Works with step-direction software.
RoHS compliant.
Individual or Simultaneous control of all axes.
Power On reset.
On board 5 volt voltage regulation (for each individual board)
PC +5Volts taken from the PC's USB port using a standard USB cable (using USB-B connector on the interface board).
Heat-sinks are not included. Dimensions for a suggested heat-sink will be shown on the documentation..
Old 01-09-2008, 06:27 PM
artwood_decor is on a distinguished road
Hi Kreutz,
using this control board and 4 steppers are there still enough free pins to be used with a 2-3 relay board which controls your spindel and a vacuum (cooling)?
Lucian
Old 01-09-2008, 11:36 PM
Originally Posted by artwood_decor View Post
Hi Kreutz,
Lucian
Pins going to the external Interface Connector are 10, 11, 12, 13, 14, 15, 16, 17. Also +5 volt or +3.3Volt Jumper selectable (from the PC) are available. And PC_Ground. So there are seven effective pins for other functions.
Pin 10 is wired OR for EMG-STOP signal. There is also a signal on the external interface connector (Active Low) used to disable external signals when the board is disabled due to the charge pump operation, could be used on the external relay board to disable vacuum, cooling, and/or spindle.
Regards,
Kreutz.
Old 01-21-2008, 08:05 PM
Kreutz-4 Datasheet
File Type: zip Kreutz-4 Preliminary Datasheet Rev01.0a.zip‎ (596.7 KB, 249 views)
Old 01-24-2008, 08:38 PM
Update. Rev3.0SMD PC Interface board modification.
Added reverse polarity and surge protection to the 12 Vdc input.
Old 01-29-2008, 12:51 PM
Revised datasheet
File Type: zip Kreutz-4Preliminary_Datasheet_Rev01.0b .zip‎ (263.1 KB, 166 views)
Old 01-29-2008, 01:08 PM
allanjs is on a distinguished road
kreutz,
What's the price ???
Old 01-29-2008, 01:53 PM
Originally Posted by allanjs View Post
kreutz,
There is a separated thread for that: Kreutz CNC stuff - sales support.
The first 25 sets will have the same price I posted for the DIY kit (not offered anymore).
Thank you,
Kreutz.
Old 02-10-2008, 09:35 PM
Modified the Over-voltage limit for the motor power supply monitoring circuit to be 47Vdc (versus 45Vdc on the specs). Tests show that it is safe to work up to that voltage. The under-voltage limit (for the motor power supply) remains at 15 Vdc.
File Type: zip Kreutz-4Preliminary_Datasheet_Rev01.0c.zip‎ (263.0 KB, 218 views)
[IMG] code is Off
Diseno de la Tarjeta Controladora Micro-Step Unipolar "Mardus-Kreutz" kreutz Spanish CNCzone 259 11-05-2011 01:04 PM
Bipolar Stepper Motor Chopper Drive (MicrostepPLD) Cyprian Stepper Motors and Drives 2 09-22-2007 02:12 PM
High current bipolar stepper drive wsc Open Source Controller Boards 76 03-29-2007 06:21 PM
Very cheap Bipolar Micro-stepper board Stevie General Electronics Discussion 5 07-13-2004 06:39 PM
