Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-04-2008, 09:03 AM
jseiler is on a distinguished road
high speed stepper
I'd like to drive a stepper at >1000rpm, so I am looking for a very low inductance stepper motor. It needs to be less than 2A. I have a keling that has reasonably low inductance driven half coil, but I has hoping to do better. I searched the forum and can't find anything related to lower current, lower inductance motors? Any suggestions?
John
Old 01-04-2008, 09:15 AM
ger21's Avatar
Low inductance motors tend to be low voltage high current. You'll have a hard time spinning a low current motor at 1000 rpm unless you can supply very high voltage to it.
Old 01-04-2008, 09:22 AM
I realize I'm fighting some physics here. I've got 44V, so that should get me in the realm of 20X spec voltage to overcome whatever inductance I see. Right now I've got this motor running half coil. Not too bad at about 4.8mH, but I suspect I can do better. I can spin this at about 1200 rpm, but the torque out there is pretty low.
http://www.kelinginc.net/KL23H256-21-8B.pdf
I haven't tried it yet, but would there be an speed advantage to running parallel on this motor for reduced inductance, even if I can only run 2A out of 3A spec'ed?
John
Old 01-04-2008, 11:51 AM
Oldmanandhistoy is on a distinguished road
Hi John,
Looking at the spec’s of the motor I would run it parallel at around 2.1Amps for highest speed and max torque if micro stepping.
If you are using a micro stepping drive it will be RMS rated not peak. The stepper motor spec sheet will very likely be rated for peak but you would need to check.
3Amps peak = 2.1Amps RMS
If you are using a full step drive then use the peak 3Amps or in your case as near as possible.
I am working form memory so double checking my info would be wise.
John
Old 01-04-2008, 03:15 PM
jeffs555's Avatar
jeffs555 is on a distinguished road
There would be no difference in inductance between running bipolar half coil and bipolar parallel. The only advantage of parallel over half coil is that it allows you to use higher current. This gives more low speed torque but won't make a difference in torque at high speeds.
PS According to the spec sheet it is 2.4mH not 4.8
Old 01-04-2008, 05:39 PM
Zappautomation is on a distinguished road
Its the other way round.
If it is microstepping use Peak.
A full step driver is a square wave so peak is RMS.
Originally Posted by Oldmanandhistoy View Post
Hi John,
John
Zapp Automation Ltd
www.slidesandballscrews.com
Old 01-05-2008, 02:44 PM
I don't think this is right, but I may be wrong. When you put two coils in series, as long as they aren't coupling, they should add in inductance. When you put two coils in parallel, they should sum 1/L=1/L1 + 1/L2, which would divide the parrallel inductance in half. The half coil inductance should be 2x the parallel inductance...or....4.8mH. Did I do something wrong here?
I found a couple of motors that are lower inductance within my current restrictions, but nothing too significant. Sometime real soon now, I'll try the current starved parallel and see if that helps over the half coil config.
John
Old 01-05-2008, 09:46 PM
jeffs555's Avatar
Your only mistake is assuming the coils are not coupled, they are. The coils are bifilar wound, in other words they take two parallel wires and wind them at the same time around the same core. If you connect the two coils in parallel, the only effect is to decrease the resistance, the inductance doesn't change. If you connect the two coils in series, it doubles the number of turns in the coil, so the inductance goes up 4 times(inductance is proportional to the square of the turns).
PS Sometimes you will see unipolar steppers refered to as bifilar steppers.
Old 01-07-2008, 08:20 AM
Thanks Jeff. That looks right and I found a few motor manufacturer's that quote inductance in half coil, and they agree with you.
Another thing I found is that higher speed is possible in half coil over bipolar series, not because of inductance, but back EMF. I think I might be OK with the motors I have, but I'd still like to locate a lower inductance 2A motor to experiment with.
John
Old 01-10-2008, 06:33 PM
kreutz is on a distinguished road
Check this video:
The drive is a Mardus-Kreutz DIY drive. The motor is a high inductance motor from Keling Technology. The New Kreutz-4 Bipolar drives get even more impressive speeds.
Regards,
Kreutz.
  #11   Ban this user!
Old 01-10-2008, 07:00 PM
pminmo's Avatar
pminmo is on a distinguished road
John
The question I would ask is what is the requirement mechanically. It's one thing to spin a stepper at such a rate, another as to the mechanical forces and loads encountered. If youre using leadsrews, you need to consider wip. If your moving any weight, you need to consider starting and stopping forces.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #12   Ban this user!
Old 01-13-2008, 11:00 AM
Indeed. I've ordered a small desktop cnc with .1" lead screws. Not expecting whip as the largest possible unsupported length would be less than 14". I'm very limited by the choice of control box, limited to 5-8K pps (don't ask ). This means that 1000rpm = 100 ipm on this particular machine. Lets pretend I can get 120 ipm or 2 ips. 2 in/sec * 200 steps/rev * 10 rev/inch * 2 pulses/step = 8000 pulses/sec. The x axis (one containing z carriage) is the only one that needs high speed and high acceleration. The Y axis can be slower and have low acceleration (due to the application). The Y axis is the one with the highest load as it needs to move both the x axis gantry and the z axis. Force is limiting to my acceleration. Acceleration is limiting my ultimate speed because of the short gantry. I won't be sure how much everything weights and how much screw friction I have until I get the machine. Once I get everything spinning and working right, I'l likely ditch the slow control system and get something with a lot more current and pps capability.
Still, any suggestions on low inductance, low current motors would be appreciated.
John
[IMG] code is Off
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 08:18 PM
High Speed Option engine tech art Haas Mills 9 05-19-2007 01:08 PM
high speed attachment tc2007 General Metal Working Machines 2 03-16-2007 07:06 PM
High speed setup Mr.Nerd Stepper Motors and Drives 0 02-28-2007 09:00 PM
High speed torque JFettig Stepper Motors and Drives 5 11-04-2004 08:15 AM
