| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Judging by the charts have for my motors (Kelling 23H276-30-8B and 23H286-20-8b) I will need .7 Ohm - 6 watt and 3 ohm - 12 Watt resistors. Where can I find these online? Locally I have zero options other then The Source and they only carry up to .5 watt resistors. Thanks, shawn |
| DigiKey have excellent service to Canada, next day air and no customs. Or In Canada ElectroSonic or across Canada local store if you have is Active Electronics. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| 3 Ohm - 12 Watt - http://www.digikey.com/scripts/DkSea...=FVTS10-3.0-ND .7 Ohm - 10 Watt - http://www.digikey.com/scripts/DkSea...name=20JR75-ND Thanks Al! Are these what I am looking for? |
| As far as I know resistors are my onmly option to limit voltage with what I have? |
| It would help to know what drives and power supply you are using, and what you are trying to accomplish. Those resistor values just don't sound right. On a non-chopper drive, those resistor values would only be good for a very low voltage supply. Also, to allow a safety factor, you generally want the wattage rating of the resistors to be at least twice the calculated value. |
| Ok, that explains it. I assume you are using the 3 ohm to run the KL23H286-20-8B off a 12 volt supply and the .7ohm to run the 23H276-30-8B off a 5 volt supply. In that case you would want to at least double your wattage ratings to allow a safety factor. |
| Ok I will try to find higher watage resisors. Thanks for the help. |
| Go to Digikey's web site. You will find what you need on a search in the online catalouge. If you need to mount a large resistor I prefer the alum. housed ones as they have the heatsink. You should at least double your wattage as mentioned. John |
| 50 Watt CO2 | kdoney | Laser Engraving & Cutting Machines | 13 | 06-29-2007 04:12 PM |
| 60 watt engraver- opinons? | replicapro | Laser Engraving & Cutting Machines | 10 | 05-14-2007 08:41 PM |
| What will 50 watt cut? | CNCadmin | Laser Engraving & Cutting Machines | 2 | 04-11-2007 04:06 PM |
| 1400 watt UPS's | dneisler | General Electronics Discussion | 5 | 01-22-2007 09:20 AM |
| Sensing Resistors vs Current limiting Resistors | whitney | Hobbycnc (Products) | 3 | 11-06-2006 12:29 AM |
