| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I have hit a bit of a road block trying to figure out my coil wires. Am I right?? I have a six wire Kelling Motor (KL23H276-30-6A) 3 Amp/Phase 2.0N.m. I am using uni-polar drivers. I think my wire config should be this: Center Tap Coil #A = White Wire #1 = Red Wire #2 = Blue Center Tap Coil #B = Yellow Wire #4 = Black Wire #5 = Green Using my ohm meter I determined the following: Wire colors = Red, white, green, yellow, blue, black. Red on Common Blue - 2.5 ohm White - 1.7 ohm White on Common Red - 1.7 ohm Blue - 1.7 ohm Green on common Black - 2.5 ohm Yellow - 1.7 ohm Blue on Common Red - 2.5 ohm white - 1.7 ohm Yellow on Common Black - 1.7 ohm green - 1.7 ohm Black on Common Yellow - 1.7 ohm Green - 2.5 ohm |
| If you ever need to work out wiring again, this web page makes it pretty darn easy: http://www.piclist.com/techref/io/stepper/wires.asp as to making that into a bipolar configuration, see: http://www.piclist.com/techref/io/stepper/wires.htm and notice that the only difference between the "6 wire unipolar" and "4 wire bipolar" is that the center taps are ignored for the bipolar setup. I take it you were asking about the bipolar only out of curiosity as you already have a unipolar driver? |
| Scratching my darn head again! ![]() I ASSumed that my 425oz Keling motor was six wires, but it is an eight wire stepper. I have read and read, and am unable to connect my motor to the driver. Wires are as follows: Red Green Black Blue Red/white Green/white Black/white Blue/white Red to Red/white - 3.7 ohms Green to Green/white - 3.7 ohms Black to Black/white - 3.7 ohms Blue to Blue/white - 3.7 ohms I have the same uni-polar driver as in my first post and I need to know these connections. Center Tap Coil #A = Wire #1 = Wire #2 = Center Tap Coil #B = Wire #4 = Wire #5 = I this info from the mft: A Blu/Wht Blu-Red/Wht B- Red C GRN/Wht GRN-BLK/WHT D- Blk |
| Dude, go to this page: http://www.piclist.com/techref/io/stepper/wires.asp and follow the directions exactly. If you don't have an Ohm meter, they cost about $12 at Radio Shack. It doesn't get any easier than that, if the wireing diagram isn't available from the mfgr. |
#10
| are you sure you don't have this motor instead? http://www.kelinginc.net/KL23H276-30-8A.pdf |
#11
| jschmitt, if you have any data on an 8 wire motor that isn't working on that page, I'd love to see that as well. |
#12
| HELP! determining brushes for DC Motor | bherr | Bridgeport and Hardinge Mills | 0 | 06-04-2007 01:45 PM |
| Determining aluminum alloy type | bdrmachine | General Metalwork Discussion | 4 | 12-12-2006 09:22 PM |
| Determining Cast Zinc from Aluminum | lwhiway | General Metalwork Discussion | 6 | 11-21-2006 09:04 PM |
| Help determining correct power resistor | mvaughn | General Electronics Discussion | 2 | 04-16-2004 04:54 PM |
| Determining VA load | Swede | General Electronics Discussion | 11 | 04-10-2004 05:00 PM |
