| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
#13
try this page then:http://www.kelinginc.net/KL23H286-20-8B.pdf |
#14
| Turns out there IS a bug in that page: It doesn't work for 8 wire motors. I'll work on it. I tested it again for 5 and 6 wire units and that is fine, as far as I can tell. It's just the 8 wire ones that it doesn't work for. |
#15
![]() I know ZERO about electrical shematics. |
#16
| B- and D are ends of second pair of parallel coils These coil ends are of same polarity. What kind of drive do you have? |
#17
| Motor info: A- -- Blue/White Blue - Red/White B -- Red C -- Grn/white Grn - Black/White D -- Black For my board I have to have the two centre wires of the coil joined in order for it to work. Does this look right? V+ -- D (Black) M2B -- ++ (Grn - Black/White) M1B -- C (Grn/White) V+ - Power for board GND - Ground for board M2A -- B (Red) M1A -- ++ (Blue - Red/White) V+ -- A (Blue/White) KITV - Logic Input Last edited by mulligan; 03-02-2008 at 10:48 AM. |
#18
It should be like this: V+ -- Grn + Black/White M2B -- Black M1B -- Grn/White M2A -- Red M1A -- Blue/White V+ -- Blue + Red/White Note also that this driver has no current limiting (according to schematic). If use a high voltage you probably blow up something at low speeds, if you use a low voltage you have low speed. Tip: you could use a 24V car bulb as a current limiter... |
#19
I have resistors to limit the power for the motor, so I should be alright there. Thanks for the help kuikkap!! Last edited by mulligan; 03-02-2008 at 11:45 AM. |
| HELP! determining brushes for DC Motor | bherr | Bridgeport and Hardinge Mills | 0 | 06-04-2007 12:45 PM |
| Determining aluminum alloy type | bdrmachine | General Metalwork Discussion | 4 | 12-12-2006 08:22 PM |
| Determining Cast Zinc from Aluminum | lwhiway | General Metalwork Discussion | 6 | 11-21-2006 08:04 PM |
| Help determining correct power resistor | mvaughn | General Electronics Discussion | 2 | 04-16-2004 03:54 PM |
| Determining VA load | Swede | General Electronics Discussion | 11 | 04-10-2004 04:00 PM |
