| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
#13
#14
| the LC filter does reduce rate of current change but not that much if sized properly. I've done this to old stepper motors and heat generated while stopped and enabled is significantly less. the filters would be a little pain though if you have to do microstepping. there are also other ways to make the winding see less HF AC ripple, mostly in the methods of recirculation. |
#16
I just have not had time to detail my setup but you can see pictures of the control circuitry on brokenhammer.com good luck and keep on experimenting. My next project on Brokenhammer will be a cnc plasma cutter or maybe the humvee project . ha virg |
#17
Virg |
#19
After 2 hours of running the motors would be warm but not hot. It's choosing the right shunt resistor. You want the motors to step gingerly and not stall out and not exceed the specification of the motor. The big fear is damaging the permanent magnets in these old steppers by creating to much magnetic flux. So choose the right shunt resistor. I'm not saying this is right. It's just a poor man's way of experimenting. I did have a smaller motor for my z axis and just used the same shunt resistor that I had used for the larger x,y motors. It got very hot and I just added heatsinks to the outside of the case. The motor (cross your fingers) is still working today. What I mean by hot (never measured it) was that I could hold my hand on it for about 4-5 seconds before it became uncomfortable. Not very scientific is it. ha Take care and keep experimenting I used a cap and large shunting diode at the motor to protect my mosfet drivers. |
#20
| motor heating may be caused by the eddy currents mainly caused by the ripples. as what Unitrode suggested in their application note, a small LC filter will reduce EMI and lower the ripple seen by the motor (I believe Gecko is using another scheme to lower ripples but not filters) thus reducing heating. EMI would be caused by higher rate of current rise. filters may help diminish them. the best way to reduce them is using common mode chokes on the wires to the stepper motor. I also put the drivers as near as possible to the motor so that the long wires may not act as antenna. |
| High Voltage wire | CNCadmin | Laser Engraving & Cutting Machines | 9 | 02-27-2012 08:19 AM |
| Is my voltage too high for motors? | johnt | Stepper Motors and Drives | 3 | 12-10-2007 02:11 PM |
| high house voltage | CASTLEVILLE | General Electronics Discussion | 3 | 12-04-2007 10:30 AM |
| High Voltage Drives | Enteralterego | Fanuc | 4 | 08-15-2006 08:08 AM |
| PSU Voltage seems high. | mnewsholme | Hobbycnc (Products) | 10 | 04-26-2005 03:26 AM |
