Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 12-01-2007, 07:11 AM
compuslave is on a distinguished road
Foolin around with an old floppy drive
I have a question that was answered here before but did not work for me. I have an old floppy tore apart and using it's native control board am attempting to at least get it to move. The problem is I don't use windows, I don't even have a copy of windows. I can't find how to experiment with this thing in linux. I compiled ltpout but it did not work. I have emc2, will that work? Its on the live disk and I haven't tried it yet.
Basically I just want to move it around a bit and experiment. Any help would be greatly appreciated.
BTW I'm using Ubuntu if that helps.
Old 12-01-2007, 02:33 PM
I found EMC to move the steppers quite readily but not very well. Thats all I wanted to do though was see some movement.
Old 12-01-2007, 03:50 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
emc2 works with steppers
Old 12-04-2007, 12:08 AM
FlyingElectron is on a distinguished road
Have you got it hooked up correctly?
Try grounding floppy controller pin 14 "Drive Select A" and pin 1 "GND" to parallel port pin 20 "GND".
Then hook up floppy controller pin 18 "Direction" to parallel port pin 2 "D0"
Then hook up floppy controller pin 20 "Step" to parallel port pin 3 "D1"
And make sure the floppy drive is powered up with the power connector which supplies both +5V and +12V.
EMC2 should work with that wiring with the standard pinout for stepper motors.
I haven't actually tried any of this, so proceed at your own risk, but it should work.
Old 12-08-2007, 01:05 PM
rickharris is on a distinguished road
Hello, Although using the floppy controller board seems logical it introduces a lot of problems/issues because it was intended to do a specific job (probably not what ou want to do)
More control can be gained by using a pic micro controller. http://www.picaxe.com is a good place to start - a UK company but available in USA and other countries.
Relatively easy to control, fairly low cost and free programming software ( I am nothing to do with them just a user.
Old 12-09-2007, 02:31 PM
I'd agree with you most of the time on that statement, but in this particular case, the floppy drive controller does exactly the job that is needed. Wierd bit of history, all the modern stepper driver boards that use step / dir signals are all descendants of the stepper driver circuitry on an IBM PC floppy drive. The IBM PC floppy drive introduced in 1981 is the product that standardized the concept of the step / dir driver as we know it today. Wow, that was the most useless piece of trivia ever to come out of my brain about stepper motors.
Old 12-13-2007, 02:12 AM
rdpzycho is on a distinguished road
some old drives have sensors that disable the motors if no disk is inserted. I encountered one that wasn't able to fully stop the motor instead the motor jerks and moves to some random position, maybe the drives were already defective. I had around 8 - 5.25" drives to play with before.
you could probably use EMC to drive them but I haven't tried it. though I tried driving a disk drive stepper using the parallel port and the internal controller. it wasn't able to push my small robot though, so I just quit that and had fun with the motor. it was my first attempt in making a wheeled bot.
Old 12-14-2007, 09:06 PM
jessbussert's Avatar
jessbussert is on a distinguished road
Try these two sites... They helped me get my floppy drive steppers spinning.
http://www.doc.ic.ac.uk/~ih/doc/stepper/
http://www.epanorama.net/circuits/diskstepper.html
Great stuff.
Jessica
Old 12-14-2007, 11:10 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Hers another site with some good info to add:
http://www.nhcad.com/flpystpr/
cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 12-15-2007, 11:17 AM
I love using cheap PC power supplies..good power at cheap prices..they are always handy at the benchtop..I also love modifying them to produce more volts or source a little more amps..
[IMG] code is Off
Floppy Drive in a 1995 VF-3 Problem Greg 24 Haas Mills 2 08-24-2007 09:54 AM
Yasnac floppy drive dewcnc Machine Problems, Solutions , Wireless DNC, serial port 0 03-19-2007 01:19 PM
Converting from Floppy Drive to USB TZ250 General Metal Working Machines 3 09-06-2006 01:55 PM
5 1/4 Floppy drive Stepper Motors High Seas Stepper Motors and Drives 9 03-17-2006 03:33 AM
Floppy Drive Cable Fiasco Al_The_Man Computers and Networking 2 11-25-2004 12:53 AM
