Results 1 to 2 of 2
Thread: Easy way to tell if the motor is good
    Apr 2005
    Is there any easy way to tell if the motor is good. When I tried to run them in mach3 they just buzz and can't seem to get the motor tuned?
    Aug 2005
    You will need to include what you are using for motors and drivers. Next would be taking a look at your connections to verify if the motor is wired to step the coils in a TEST MODE. Power supplies. Drag on the slide assembly. Then look into your output pulse data paramters in the software etc. Let the process of elimination lead you from the obvious to the curious. There is a needle there somewhere.
    Basically, if it don't work......it aint good, but it may not be the motor. Have you done any other tests to rule out the above?
    DC
    Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
  1. Easy to build CNC Mill Stepper Motor and Driver circuit
    By Tom McWire in forum Open Source Controller Boards
    Last Post: 03-31-2010, 11:09 AM
  2. Good, Easy to machine Steel (not 12L14)?
    By Builder4wd in forum General Metalwork Discussion
    Last Post: 09-24-2006, 10:33 PM
  3. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors and Drives
    Last Post: 12-02-2004, 12:31 AM
  4. Is this a Good Stepper Motor
    By Biggermens in forum Stepper Motors and Drives
    Last Post: 11-03-2004, 06:57 PM
