| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| I have searched the net to no avail for the wiring for a superior electric slo syn stepper mo-63. This should be easy. The connector has the wires in the following order ,red,black,brown,green,white,blue.A six wire motor.Im using gecko g-201's.Should I just use the first two and last two.(black,red,white,brown) and ignore the two center wires? Or should I be worried that they are o.e.m. orders with odd wiring. Also would I just connect the two center wires together? Thanks all for any help. P.S. I suggested along time ago in the forums that someone should start a new category for a motor wiring data base. I know it would get alot of use. |
| Use a multimeter to measure the resistance between the various wires. Since you have a six-wire motor, three of the wires will go to one coil and three of the wires will go to the other coil. For instance, on an M092-FD09 motor that I have, one coil has Red, Black and White/Red wires. The other coil has Green, White, White/Green wires. The Red and White/Red wires on one coil and the Green and White/Green wires on the other coil are used with Bipolar Series wiring. Either the Red and Black or the Black and White/Red wires on one coil and either the Green and White or the White and White/Green wires on the other coil are used when the motor is wired half-coil. Because the motor only has six leads, it cannot be wired Bipolar Parallel. Bipolar Parallel wiring requires eight lead motors. If I may be a little blunt, why are you using that old motor? Motors and drivers are the very heart of a CNC machine. Instead of trying to make an old motor work, why not save up $50 - $100 and buy a new powerful square type motor that has a data sheet? Personally, I always use Oriental Motor stepper motors and Gecko stepper drivers in all of my designs. I often tell newbies that they can work one week-end at the local McDonalds and earn enough money to buy a quality stepper driver and a quality stepper motor, or they can spend weeks messing around with old stuff in an effort to make it work. I consider any round motor to be old stuff and not worth much effort. (I keep a drawer full of old Slo-Syn motors and old PK299 motors to show visitors. They're interesting to look at but nearly worthless when serious work needs to be done.) |
| Over the top easy question from total noob. | GregoryA | General Metalwork Discussion | 4 | 10-01-2005 09:41 AM |
| Easy question, Hard solution | CBNDude | Mechanical Calculations/Engineering Design | 11 | 06-10-2005 01:04 PM |
| Stepperworld SP-3/HT wiring question(easy one) | FlyElectric | Stepper Motors and Drives | 8 | 04-17-2005 06:07 AM |
| easy to answer question | senor J. | Mach Software (ArtSoft software) | 2 | 01-27-2005 06:34 PM |
