| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello guys! I just assembled the electronics for my under construction CNC mill, however i'm having trouble getting any speed out of the motors. Driver is a simple circuit based on L297 and L298, the motor supply voltage is 46volts. Motors specifications: Bipolar 2-phase Holding torque 1.25 Nm Nominal current 1.4 A Coil resistance 4.2 ohms Coil inductance 15 mH I have been experimenting with EMC2 (linuxcnc.org), motors are currently set to full step. I can't get them above 250 rpm, they sound fine and run smooth, but when i increase speed over about 250rpm they sound the same but they don't spin. Am i simply going to have to accept this? It seems a little slow to me but i don't know. Thanks for answers. |
| Hi. Do the motors have any load on them? If not, try dropping the current a bit for faster no-load speed (or change current decay). Once it's mounted and loaded you might be able to get more speed out of them. The impedance/inductance seem a bit high which may also contribute run performance. For reference, my Bodine steppers are 1.18 ohm and 3.14 mH. JR |
| Hello. Yes I have played around with acceleration a bit and at this moment 333rpm is the fastest i can get without any tendency to stall. If I increase it to 350rpm it starts stalling now and then, it accelerates at the beginning but then it stops spinning. Acceleration is currently at 10mm/sec˛ I have focused on tuning in full step mode, should it be wiser to focus on half step? Or which one should be faster? |
| JRoque> The motors doesn't have any load currently. They are just sitting on my desk ![]() Yes, the inductance is pretty high too bad I didn't think of that when i bought them.. it's my first time using steppers so i don't have a lot of experience on these things...Hmm, so lowering the current gives better speed? And putting load on the motors would make them get better speed? Thanks for your tips! I will try it out and post the results. |
| Ok now i'm beginning to get something. Switched to half step and lowered the current to 1Amp = 650rpm and much smoother running. I can go up to about 700rpm but then i can stop the motor with my fingers if i squeeze hard i guess i will have to see what they are capable of once mounted.If anoyne has any other tips please let me know, and thanks for your help guys. |
| Beltdrive-stepper motor-stepper motor driver | Georg | Stepper Motors and Drives | 0 | 10-16-2007 04:56 PM |
| Stepper for Spindle Speed | danielm | Stepper Motors and Drives | 3 | 08-06-2007 11:18 AM |
| Stepper motor speed\voltage question? | cwdance1 | DIY-CNC Router Table Machines | 4 | 03-28-2006 04:26 PM |
| stepper motor speed | AlanETM | Stepper Motors and Drives | 1 | 01-05-2006 09:17 PM |
| stepper motor speed question from newbie | designit | Stepper Motors and Drives | 5 | 10-04-2005 08:25 AM |
