Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-01-2007, 03:26 AM
Bit Bucket is on a distinguished road
Info on Japan Servo KP39HM4-016
Hi, this is my first post!
During a recent trip to Tokyo, I found 10 Japan Servo KP39HM4-016 for just 12$, so I got them to my home in Italy hoping to use them in a robotic project.
The question is: may I use them for a small CNC table?
I don't have a datasheet, but searching the web I found:
- they come from old 5.25" floppy drive
- they are labeled Matsus hita
- US Patent 4,347,457
- DC 12V, 0.08A
- 3.6 deg/step
- 4 wires (bipolar?)
- I found even a picture! http://www.wakamatsu-net.com/cgibin/biz/62020009.jpg
Reading this GREAT forum, I am starting to think that my stepper are too small for a CNC.
Can someone let me know how can I experimentally search for the torque?
Can I improve the torque using a gear train or maybe a timing belt or a worm gear?
Please, note that I only need a small CNC (about the size of an A4 paper sheet of working space).
I'd like to mount on it my Dremel (or an extrusor like fab@home), and that I'll use it to: cut PCB tracks and component holes, mill polystyrene foam, cutting MDF max. 1/2 inch. thickness and maybe fiberglass sheets.
Thank you for any help and sorry for my bad English!
Old 11-01-2007, 09:13 AM
One of Many is on a distinguished road
Considering its native application, there is no where near enough torque to move an axis much greater than a floppy drive head with nil for resistance. Add to that some cutter pressure and I'd imagine all it will do is hum a few unfamiliar tunes. A better application is this Theremin that could make the tunes play something you know.
You may have already found this link.
Drivers for your motors
All this does is motor control a potentiometer.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
[IMG] code is Off
Japan Servo KP8M2-011 Info ? ? ? scratch_6057 Stepper Motors and Drives 1 09-26-2007 11:40 PM
HELP ! specs sheet for japan servo co ltd norw1946 Servo Motors and Drives 0 06-12-2007 02:53 PM
japan servo wiring diagram norw1946 Stepper Motors and Drives 2 12-21-2006 02:43 PM
Japan Servo DS57F40-1 marvinstov Servo Motors and Drives 2 04-28-2006 04:24 PM
Japan Servo Co. Some information needed phantomcow2 Stepper Motors and Drives 4 08-12-2005 11:08 PM
