Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-02-2004, 10:27 PM
Sanghera is on a distinguished road
Stepper Motor Wiring
I have bought 3 motors and I haven't found any information on which wire is which so far. They are 8 wire Unipolar Bipolar motors. How can I find out which ones are ground and step and direction? For unipolar what are all of the wire possibilities. Eg. Ground, Step Dir, Step Dir, for one motor?
Thanks.
Old 06-02-2004, 11:06 PM
Gold Member
marvinstov is on a distinguished road
Hi Sanghera,
Me again. If you have 8 wire motors then take a look at this: http://www.xylotex.com/PacSciIB.pdf
By the way, you are using a Xylotex board right?
Marv
Old 06-03-2004, 04:15 PM
jfirey is on a distinguished road
Hi Sanghera,
I have some wiring diagrams for the Pacsci Powermax II, octagonal case motors motors to the site's gallery. The wiring concept is the same for all 8 wire motors. They may be useful to you.
Bipolar series wiring for pacsci
Bipolar parallel wiring for pacsci
Unipolar wiring for pacsci
The color codes and shield drains relate to the particular wire I use in the cables that I make. Be sure to not be misled by the color of the outputs, just 'follow the lines' to build with your own cable.
Jason
Old 06-03-2004, 10:23 PM
CrazyRonny's Avatar
CrazyRonny is on a distinguished road
Maybe this link could help you, it's a complete tutorial about stepper.
http://www.cs.uiowa.edu/~jones/step/index.html
I have see another simple tutorial to determine what cable does what on your stepper but I could not find it.... I will search and let you know if I find it.
Good luck
CrazyRonny
Old 06-04-2004, 02:50 PM
Dogsione is on a distinguished road
Stepperworld.com also has a simple tutorial that may help:
http://209.41.165.153/stepper/Tutorials/UniTutor.htm
You can use an Ohm meter to find the center legs and then go from there.
Good Luck
Old 11-06-2004, 05:33 PM
bunalmis's Avatar
bunalmis is on a distinguished road
Possible configurations with 8 wire step motors
http://www.cnczone.com/gallery/data/500/1242coklu.jpg
[IMG] code is Off
Attaching a Stepper andy_ck87028 DIY-CNC Router Table Machines 4 12-24-2004 12:09 PM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-02-2004 12:31 AM
Stepper motor spec' source & question Damachine DIY-CNC Router Table Machines 4 04-06-2004 02:01 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 02:18 AM
disassembly of stepper motors dhprc2 General Electronics Discussion 8 06-25-2003 08:09 PM
