Results 1 to 9 of 9
Thread: Compumotor a83-135 ... amperage
    Jan 2005
    Does any one know the amperage rating for a Parker Compumotor a83-135 stepper?
    Aug 2005
    Depends on how the motor is wired. In series or parallel. 3.47 for series and 6 for parallel. You can check the winding resistance or look at the cable connection to figure out which way it is being used. Normally these are driven with an 6S, 6SX or Zeta4 drive, but seems to me I have seen some data that they will run on a S8 drive near 8amps in parallel for short durations.
    Parker S drive PDF
    DC
    Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
    Jan 2005
    only 4 wires, 2 coils. think A Series.
    Aug 2005
    Chances are that it is just wired in series internally and they only pulled 4 leads out. I am fairly confident that should still put it at 3.47amps as all of the 83-135 fit the same current spec.
    Email support at Parker?
    DC
    Jan 2005
    Let's explore the "Common Sense" feature.
    What is the effect of low amperage?
    What is the effect of high amperage?
    Aug 2005
    Oops, looks like I was wrong after a bit more looking into Parkers web site obsolete products. The A series were high inductance motors and used near 1/2 the current the low inductance S,SX and Zeta series do.
    Thanks for compelling me to question my own assumptions!
    A drive manual
    DC
    Jan 2005
    How do you "look around" on their site?
    I can find no way to search their "obsolete equipment" and it would be immensely helpful.
    Thanks for the effort and data!
    John
    Aug 2005
    I don't think the obsolete section is included in their search path\results. I've spent most of my compumotor time on the more current and mature class products. It may be a better plan to Google the "A83-135" unless you are used to the Parker format.
    DC
    Registered Miata2k's Avatar
    Jul 2006
    I realize that this is an old thread, so if you still need the information on this motor I have a copy of the specs that I can email you.
    As a side note if anyone else has any more of the Parker A series Stepper motors I would be interested in buying them or trading for them. I just acquired a few of the A-series drives, but I'm having a horrible time finding the motors.
    I have the Parker Compumotor microstepping drive (AHL-Driver) and they need a high inductance stepper motor, over 20mH, and they are just hard to find.
    It is also compatible with the following motors.
    AX57-51
    AX57-83
    AX57-102
    AX83-62
    AX83-93
    AX83-135
    AX106-120
    I'd also be interested if anyone has found any other High inductance motors.
    1. Compumotor microsteppers
      By Stevie in forum General Electronics Discussion
      Last Post: 11-15-2007, 09:35 AM
    2. Any Specs ? Compumotor S57-102-MO
      By epineh in forum Stepper Motors and Drives
      Last Post: 08-10-2006, 03:14 AM
    3. compumotor and parts
      By tekno in forum General Electronics Discussion
      Last Post: 06-29-2004, 06:46 AM
    4. Compumotor B23 Brushless Servo???
      By CRFultz in forum General Electronics Discussion
      Last Post: 04-15-2004, 10:42 AM
