| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| What voltage is it rated for? what you might have is a synchronous motor, they are the same construction as a stepper and use three connections, two direct across the AC and the third wire is connected to a capacitor, the other side of which is connected to the AC hot. They usually run at a constant 72 rpm on 60hz supply. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Bummer.. Wonder if I can resell this to someone when it gets to me. Bought it blind, with no information, and now i am fairly sure i made a mistake... guess I will live and learn not to be impulsive, and take a chance on losing an item, rather than buying without enough info first.. I figured I was just not seeing all the wires in the pic, until I happened to see a mention of a 3 wire ac stepper, and since this one is listed as a Synchronous/Stepper motor, I am sure that is what I bought. Eddie |
On the other hand those motors are usually rated for A.C. line-voltage so their inductance is likely to be very high. That would keep you from stepping them very quickly. James |
| Attaching a Stepper | andy_ck87028 | DIY-CNC Router Table Machines | 4 | 12-24-2004 12:09 PM |
| Not good for a stepper motor? | FLUTE HEAD | Stepper Motors and Drives | 4 | 12-02-2004 12:31 AM |
| Stepper motor spec' source & question | Damachine | DIY-CNC Router Table Machines | 4 | 04-06-2004 02:01 PM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
| disassembly of stepper motors | dhprc2 | General Electronics Discussion | 8 | 06-25-2003 08:09 PM |
