Results 1 to 8 of 8
Thread: ounces??
    Registered Nitroghost's Avatar
    Jul 2007
    ounces??
    What is the best way to determine how many ounces a motor is? i have a fastron type 23KM-K307-G3V. it is out of a tektronix Phaser 850 printer.
    Aug 2005
    ...energize it and use a torque wrench (if you have a light weight oz/incher)
    Jul 2007
    i wish i did. this is all i could find.
    Model Size= 56mm
    Step Angle= 1.8deg
    Torque Range= 400~1500mNm
    Max Input Current= 3.0 A
    Resistance Range= 0.6~28
    Jul 2005
    Quote Originally Posted by Nitroghost View Post
    Model Size= 56mm
    Step Angle= 1.8deg
    Convert this to oz-in, you should be able to find a conversion factor using Google.
    Mar 2005
    ENGLAND
    56.6 oz in~ 212.4 oz in
    Jul 2007
    Thanks "oldmanandhistoy" i have been looking for the conversion factor. Is this a good motor to start with? I am going to be milling wood, plastic and eventually aluminium. Do I want to go with a bigger motor later on? Thanks
    Mar 2005
    ENGLAND
    Down load the converter here http://www.cnczone.com/modules.php?n...warticle&id=23 for Windows.
    Have you got the machine frame built/bought yet?
    If not forget about the stepper motors and electronics until you have; unless you are on a tight budget and need to estimate costs first.
    If you have then it is impossible for anyone to advice on stepper motor recommendations without a lot of information about the machine frame.
    Have a look at this thread for calculating stepper motor size. What motor, screw and gearing should I choose? v1.2
    John
    Jul 2007
    working on the top half right now. getting ready to start on the screw and the axis nuts. this is all new to me and i am taking it slow so i can research any problems that come up.
    1. Injection plastic - ounces/grams question?
      By Wargamer in forum Moldmaking
      Last Post: 05-16-2007, 09:10 AM
