You can't re-adjust the one of the coupling locations on either the screw or the motor shaft?
My understanding is that you do not want any significant load on the stepper bearings.
-Jeff
My cncfusion kit just showed up. I'm curious about one part of the assembly. The steppers don't bolt up without a bit of force applied. No great amount of force, I can seat them using thumbs and finger pressure. Is this OK or should a bit of shimming/filing be done to eliminate this? The lovejoys seem to be able to compress a bit.
Can't tell you the exact model of stepper. They were supplied by Xylotex.
-Jeff
www.JeffAlbro.net/cnc/
Removed both lovejoy setscrews to check that. The motor still sprung back from it's mounting plate a small amount. Probably a burr needs cleaning up or something.
Should I admit that I thought the "compression" might be a designed feature? New to this obviously
Thanks Jeff. Nice website btw.
