Results 1 to 6 of 6
Thread: need 3phase stepper drive chip
    Registered stragenmitsuko's Avatar
    May 2007
    na
    Folks , now that I've discoverd the zone , I spend the entire aftrenoon
    on my parents attic loooking for a shoebox filled with steppers I tucked
    away 15 years ago . And I found it .
    Inside there were 3 little gems ( pitures) I compleately forgot about .
    Perfect to build a small router for engraving and pcb drilling / milling .
    3phase /30Volt bipolar .
    And I have 3 of them
    But the downside is that there doesn't seem to be any 3phase driver chips
    available .
    As usual , every help appreciated .
    Pat
    Attached Thumbnails Attached Thumbnails need 3phase stepper drive chip-3phase_1.jpg   need 3phase stepper drive chip-3phase_2.jpg   need 3phase stepper drive chip-3phase_3.jpg
    May 2007
    na
    Here's a pdf explaining the stepping sequence for both full and halfstep unipolar and bipolar configurations .
    It's about the only usefull information google came up with .
    Attached Thumbnails Attached Thumbnails need 3phase stepper drive chip-3step_logic.pdf
    Dec 2004
    Barbados
    Check out aanrip's site for the 3 phase stuff.
    http://www.aanrip.nl/cnc.htm#nwdriv
    Jason
    May 2007
    na
    Interesting site .
    Looks like he's on hold though , same problem . No driver chips for the 3phase steppers .
    Apparently there aren't any integrated logic chips that can drive 3phase steppers apart form the hitachi HA13532 wich is unobtainable .
    So I guess its gonna be back to discrete logic chips if I'm gonna
    use these . Or maybe gal's . Boy , that's 20 years ago . Need to do some more digging in my partents attic .
    Pat
    Jun 2005
    The Netherlands
    Quote Originally Posted by stragenmitsuko View Post
    Interesting site .
    Pat
    I build the drivers for Aanrips router, which is now mine.
    The motors where saved from Konica copiers and we took the drivers and controllers from the original driver board. Because we have more motors then driver chips I searched the net but did not find another solution. I planned to use a microprocessor as controller, but because it is years ago that I programmed uP's and CNC got a lower priority in my doings it did no come to it yet. It is still on my todolist so, If I get the spirit and take the time I will inform you about it on this forum.
    Absat.
    May 2007
    na
    I'll probably build a driver with some C-mos logic and 3 full bridges like an L298 or similar . Schouldn't be all that hard .
    I'll post the results right here if I get it to work . If I ever find the time that is .
    Pat
    1. Where can I buy stepper chip sla7052M ?
      By seanreit in forum Hobbycnc (Products)
      Last Post: 04-07-2007, 10:18 AM
    2. * Please help - What do you use for 220V 3Phase imported DRIVE + MOTOR?
      By cjchands in forum General Electronics Discussion
      Last Post: 03-21-2007, 08:01 PM
    3. new stepper chip 4 motors Step/direction to phase
      By news in forum Product and Manufacturer Announcements
      Last Post: 08-04-2005, 07:47 AM
    4. 3phase servo retrofit
      By whiteriver in forum Servo Motors and Drives
      Last Post: 02-06-2005, 10:27 PM
    5. 3Phase motor, is it good.
      By Alan T. in forum General Electronics Discussion
      Last Post: 12-01-2003, 12:01 AM
