Results 1 to 6 of 6
Thread: Drive has CW/CCW, need to hook to LPT
    May 2003
    Drive has CW/CCW, need to hook to LPT...
    I have tried everything, I can only get the stepper to go in one direction or the other, after a change in MACH.
    Is there a specific way to hook Step/dir output from printer port, to the CW/CCW inputs of a stepper drive?
    What is this type of drive called?
    Thanks for your help guys....
    Regards,
    Justin
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    Have you configured you pins in mach? Are you referring to a step/direction drive?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    Dennis
    May 2003
    No I am not refering to a step and direction drive. The inputs are labeled F+ , F- , R+ , R-.
    I have successfully used the lpt to spin the motor on these inputs, but only in one direction, corresponding to the hookup.
    I am wondering if I have to use a hex inverter, or if there is an easier option.
    The drives say PACK DRIVER, made in japan. I believe they are made by MYCOM.
    Justin
    May 2003
    Thank you Dennis, I have been following that.
    But to be honest, That picture dosen't tell me what to buy. I am not an EE, and am limited in diagram interpretation.
    TO me it looks like two switching transistors forming a NAND gate.
    There is like, 10 trillion transistors out there.....which one two buy?
    ....if those are even transistors.....
    Aug 2005
    Clearwater, FL US
    The AND gate ic is a CMOS 4081 and the OR gate is a CMOS 4071. RadioShack might have the ic's, here is a link to more info on how they work.
    http://www.doctronics.co.uk/4081.htm
    Dennis
    1. C-Hook programing
      By Russler in forum Mastercam
      Last Post: 01-14-2007, 09:56 AM
    2. fanuc 3m on hook up to pc
      By Gpestarters in forum Fanuc
      Last Post: 07-27-2006, 10:31 AM
    3. How do I work out which wires to hook where.
      By Apples in forum Stepper Motors and Drives
      Last Post: 08-30-2005, 07:33 AM
    4. C Hook
      By Graphcon in forum Mastercam
      Last Post: 01-11-2005, 02:06 PM
    5. board hook-ups
      By landart in forum DIY CNC Router Table Machines
      Last Post: 11-29-2003, 10:49 AM
