Results 1 to 5 of 5
Thread: Stepper Motor Power
    Feb 2007
    Question Stepper Motor Power
    Hi
    I recently finished a linear translation table using this motor:
    http://www.eminebea.com/content/html...pm42s096.shtml
    I tested the motor with a Linistepper configured to give out 0.2 Amps and 36 Volts. However, the motor was not able to move the carriage. I have another Linistepper that I can configure to give more amperage. According to the spec-sheet, the bipolar chopper current/phase is .5A. Does this mean I should configure my other Linistepper for .5A? Or should I go for higher voltage?
    Thank you in advance
    Kyle
    Feb 2007
    I guess what I'm really asking is what is this motors:
    amperage? According to the table the current/phase is 500mA for a Bipolar Chopper. So should I configure the Linistepper to give the motor 500mA?
    As you can see, the spec sheet leaves the box empty for current/phase under Unipolar Constant Voltage.
    Feb 2007
    Now I am terribly confused. It turns out the LiniStepper is a constant current driver, and the eMinebea datasheet is for a constant voltage driver. What is the difference between these?
    Kyle
    Aug 2006
    You can use it on a linistepper (unipolar drive) adjusting the current for 0.266 A (266 mA), and a 36 to 48 volt power supply. Your power transistors are going to get hot, so use a good heatsink with a fan.
    Note: 24 volt/ 90 ohm = 0.266 A.
    Feb 2007
    Talking
    Thank you very much, kreutz
    1. Stepper motor power ratings?
      By decoder in forum Stepper Motors and Drives
      Last Post: 04-16-2007, 07:24 PM
    2. Stepper Motor Power Requirements
      By GAWnCA in forum Mechanical Calculations/Engineering Design
      Last Post: 04-07-2007, 02:44 PM
    3. How to find out how much power (oz/in) do I need for stepper motor?
      By max7687 in forum Stepper Motors and Drives
      Last Post: 09-18-2005, 04:57 PM
    4. help on stepper motor power supply
      By ahmed in forum Stepper Motors and Drives
      Last Post: 06-14-2005, 12:56 PM
