Dear Alex,
Steppers run hot. What limits the maximum temperature at which you can run a motor is the temperature rating of the insulation.
For example....
NEMA class A insulation is good up to 105 degrees centigrade. That means that if ambient is 40 degrees C, the motor coil can cope with a temperature rise of 65 degrees C.
Here is some good stuff on the matter..
http://cipco.apogee.net/mnd/mfnrins.asp
Best wishes
Martin
LinkBack URL
About LinkBacks
