Welcome to the forum. That appears to be a standard L297/L298 setup. Should probably work fine.
If you want to build a drive, you should also check out www.pminmo.com . He has details for many different drives. This one http://www.pminmo.com/l297-8/l297-8.htm should be very similar to the one you linked.
LinkBack URL
About LinkBacks
